P1SC max boost???
Old Aug 18, 2006 | 12:13 PM
Mr.Big's Avatar
Mr.Big
Default P1SC max boost???
What is the true max boost a P1 is reliable for??? Trying to see if I should convert to a D1, or if my P1 is fine for up to XX lbs. of boost...
T.I.A.
Jeremy
Old Aug 18, 2006 | 12:19 PM
brandon1566's Avatar
brandon1566
ive heard mid to upper 20's dont quote me on that though
Old Aug 18, 2006 | 01:01 PM
Emuffinman1's Avatar
Emuffinman1
My friend made over 700 rwhp with a P-1. Boost is relative and you can't believe everything you read on the forum. A P-1 has to work harder to make the same power as a D-1.
Old Aug 18, 2006 | 05:53 PM
chriswtx's Avatar
chriswtx
peter pan is making 742rwhp with a P1sc at 14psi of boost on a 346ci. And that was only at 6000rpm where they stoped the dyno runs at. It would have made more. He didn't want to run it any higher to keep it reliable...
Old Aug 18, 2006 | 08:20 PM
402Sam's Avatar
402Sam
Damn thats the highest I have heard from a p1.
Old Aug 18, 2006 | 08:25 PM
torchvette10's Avatar
torchvette10
Hi Chris,
Peter pan is running a D1SC, not a P1
The highest I have seen on a P1 was 711 RWHP and don't know about the boost
Old Aug 19, 2006 | 12:35 PM
Mr.Big's Avatar
Mr.Big
Just curious about reeal world numbers, the factory specs never tell the truth... Thanks for the help guys...
Jeremy
Old Aug 19, 2006 | 01:58 PM
chriswtx's Avatar
chriswtx
Originally Posted by torchvette10
Hi Chris,
Opps, yor right. He's got the D1sc...
Old Aug 19, 2006 | 02:38 PM
Laguna Blu's Avatar
Laguna Blu
Man if those numbers were on a stock bottom end he would have the world record. What's the RWHP figure before forging becomes necessary?
Old Aug 19, 2006 | 03:06 PM
1 Nasty Z's Avatar
1 Nasty Z
Oh man he has me beat. by a couple hp.
See this thread:
http://forums.corvetteforum.com/show....php?t=1440477
Old Aug 19, 2006 | 03:44 PM
chriswtx's Avatar
chriswtx
No forged bottom and D1sc not the P1sc..
Old Aug 19, 2006 | 04:40 PM
Laguna Blu's Avatar
Laguna Blu
Wow, unreal. I do believe that the LS6 has a stronger bottom end than my LS1 so I'm probably looking at a maximum of 500 RWHP for my application.....but I'll take it......for now.
Old Aug 20, 2006 | 08:40 AM
torchvette10
Peterpan has a forged 346 from A&A Corvette (forged pistons and rods) with higher flowing heads.
Also the LS6 stock is running a higher compression ration than the LS1. So it is a little bit less boost friendly than the LS1.
Old Aug 21, 2006 | 01:31 PM
xlr8shn's Avatar
xlr8shn
http://forums.corvetteforum.com/show...SC&forum_id=86
Old Aug 21, 2006 | 02:41 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
As a FYI - from 2000 onwards, the LS1 & LS6 bottom end were the same. I know your have a '99.
Old Aug 21, 2006 | 04:20 PM
Laguna Blu's Avatar
Laguna Blu
I've read a few posts which state that the LS1 takes to the boosting real well since the compression isn't as high as in the LS6. Would this even out the playing field somewhat?
Old Aug 27, 2006 | 07:46 PM
hogurt's Avatar
hogurt
I am running about 10psi on a 372ci motor.
R
To P1SC max boost???
Old Aug 27, 2006 | 07:58 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Jeremy
Nice numbers you have out of that PS1C, is your bottom end stock, if so you probably do not need to turn up the wick any higher, you can add some meth to make it a little safer.
If you have a C6 with a forged bottom end then you can turn the wick higher that is for sure. I kept my little ole 346 to 14lbs and shut her down at 6200. If I see the need to up the boost my first step is to raise the rev limiter to about 6800 and see what I get. On my DS1C I use a 3.85 pulley to hit my 14lbs. So if you are forged there is no reason that you can not turn the wick up so you can see 14+ lbs and again I would install a meth kit for some added protection.
Good luck with your quest for more HP
Old Aug 28, 2006 | 08:07 PM
PRAY's Avatar
PRAY
I have a 4.10 pulley on my cammed and headerd 02 Z06. My P1 made 10psi at 6,700 and 632rwhp with a below 10:1afr and 14.5* of timing. So I would guess it would make about 12-13psi with the 3.85 pulley I have waiting to go on. I would just start to worry about IAT's at that point though. I don't have meth yet either so right now I run a restrictor plate. I think in the future I am going to find the limit of this head unit though.
There is another guy making 10psi and 675rwhp on a 383 with a P1.
Brett
Old Aug 28, 2006 | 08:28 PM
Tsab's Avatar
Tsab
I'm making 653RWHP at 8.5 psi on a stock bottom end with a P1SC-1. I'll be going with a forged bottom end soon and turning up the boost to 14 or so PSI.
