Cool. I think you will find the MSRP of the C5 twin turbo system very attractive for a highly engineered and very complete intercooled twin turbo package. I hope to have firm pricing by the end of September.
With the right combination engine...............high octane fuel.................thorough tuning..................meth injection...............low restriction exhaust system.................sufficient fuel supply...................around 850 to 900 whp would be my best estimate.
Will you be using the same turbos on the C5 kit that are on the C6 kits that are being installed now? Do you forsee an option of larger turbos for guys with forged lower compression motors and or larger cubic inches?
No. How much power are you really looking to generate? The base turbos in the C5 twin turbo system should cater for 99% of what power/torque that most guys will ever imho. Have you ever drive a car with 800/800 rwhp rwtq? Scares the absolute crap out of me .
The extra weigtht of stainless steel tubing compared to mild steel exhaust tubing is very minimal, well worth going with stainless steel for exhaust tubing imho..............and just looks oh so pretty.
Originally Posted by SpeedyD
I know it will last forever, but is there another reason? Or is it not much heavier than other options and the last forever feature out ways the weight cost? Looks Great though!! Thanks, Dan
Going with 304 grade stainless steel tubing is far more duarble at higher exhaust gas temps (lasts much longer than mild steel exhaust tubing) and I learnt many years ago about the salting of roads in the US and Europe, mild steel exhausts go rusty very quickly and fall apart after approx 18 to 24 months.
850 rwhp on a forged LS2 402 built for boost (9.0:1). I just want to make sure that the turbos in your kit will not run out of breath on 402 cubic inch LS2 with AFR 225 heads and a 90mm TB and FAST intake, since they were chosen to work on a 346 ci LS1 with stock heads and intake.
Perhaps, they might beable to offer the ability to adjust the size of the turbos when you purchase the kit. This way they will just use the turbos from their APS C6 package (turbos might need to be re-clocked?) for a C5 with a forged LS2.
And for those bitching about no brake cooling ducts. Unless you have DRM extensions the don't do ****. They're more like tire edge cooler things in the stock configuration.
If you really want cooling you can run race hose to cut mobil 1 bottles under the front bumper... works great.
Also... if you're a track nut FI is the wrong way to go.. build a nasty NA 427 of 402.
With the right combination engine (346 to 402 ci)...............high octane fuel.................thorough tuning..................meth injection...............low restriction exhaust system.................sufficient fuel supply...................around 850 to 900 whp would be my best estimate.
