boost gauge ?
Old Aug 26, 2006 | 05:06 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default boost gauge ?
got my car back and my boost gauge isnt working ?? where should i look to make sure everything is okay ?? help !!!
Old Aug 26, 2006 | 05:34 AM
mdhmi's Avatar
mdhmi
What type of boost gauge are you using and how and where is it connected?
Old Aug 26, 2006 | 08:32 AM
wrustywrench's Avatar
wrustywrench
it works, you just got no boost...
lol
I tried to call, got no answer...musta been out doing burnouts
coming to wabash today,,,,when can I see your blower ( and I dont mean girlfriend)
Old Aug 26, 2006 | 08:54 AM
js23881's Avatar
js23881
If its a vacuum boost gage look under the hood, drivers side by the brake vacuum boost module. Look for a plastic tube and make sure it is not kinked and it is Tee'd into the vacuum line coming out of the booster...usually with a 1/8th, 3/16th compression fitting in a brass tee.
Old Aug 26, 2006 | 09:38 AM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
yes thats what it has it got liek 2 t's the meters are auto meter sport-comps the fuel is working jus no boost? ill check the m for kinks !! thanks jay
To boost gauge ?
