Thanks for the pics Mr. Big! Are these the 52mm ones? Is that the Autometer Dual Pillar Pod? I have heard that you need to have "one link controller" to make these gauges work. Is that true?
I have a mechanical boost and electric fuel pressure gauge from Defi, along with a pillar pod and associated A-pillar that I will be selling soon. If you're interested, let me know.
Only exception is I might not have the black plastic surround, instead the gauge bezel is aluminum -- a near perfect match for instrument clusters with the aluminum rings around them. In fact, I was told the same company that makes the Defi gauges also makes the Corvette instrument cluster / face. Not sure if that's true or not?
defi are awesome gauges, i would go with the 60mm and then just use a dremel to make the holes bigger on your autometer pod, that is what I did in my supra with great success
