CODE help needed
Old Oct 28, 2006 | 06:16 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default CODE help needed
Okay guy's need a little help here. Got that light on the dash and 2 codes showing...........1. P0410 AND 2. p0440 Both are listed as H & C when I clear them they stay off for a few days but they come back. What do I need to do????
Old Oct 28, 2006 | 06:23 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
0410 is for the air injection system
0440 is for the EVAP system
I would assume your AIR system is gone? So those codes need to be disabled by your tuner.
Your EVAP system needs to be gone over and find the problem though. If you really wanted to you could probably disable those too, but if the system is on the car you might as well fix it.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Oct 28, 2006 | 07:17 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Thanks Nick...I will have him check it out. Time for the 4 year test in the great state of IL.
To CODE help needed
