new gate
Old Nov 8, 2006 | 09:19 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default new gate
check this sucker out!
http://www.ls1tech.com/forums/showthread.php?t=605557
Old Nov 8, 2006 | 10:19 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Tials not doing the trick for you?
thoes do look pretty slick, how are the piston ones any different?
Old Nov 9, 2006 | 10:31 AM
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
They use no diaphram, so no ballooning under high heat and high pressure. These gates are built to survive the most extreme setups and not fail.
Jose
Old Nov 9, 2006 | 11:12 AM
Earl H's Avatar
Earl H
Isn't this overkill for most of our setups? Nick...note I said most...I can see you in the few years posting a question about fitting Thumpers on a new 500CI FI Warhawk Block
I feel so small and inadequate...
Old Nov 9, 2006 | 01:01 PM
AVB's Avatar
AVB
I feel priviledged to be able to know NICK during his infancy!!!!
Old Nov 9, 2006 | 01:08 PM
Skunkworks's Avatar
Skunkworks
Actually you can say you knew him when he got 100 miles between drivetrain rebuilds…
Mike
Old Nov 9, 2006 | 03:20 PM
NICK YOSKIN
St. Jude Donor '08
you guys!!!!
Old Nov 9, 2006 | 03:29 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
I only have one thing to say to you Nick.
BACK HALF
Talk to you when I come back from St. Marteen.
Old Nov 9, 2006 | 03:48 PM
NAVY08's Avatar
NAVY08
Mike
burn
I feel privlaged to have been sideyaws at 80 with nick at the wheel
Old Nov 9, 2006 | 05:03 PM
Baldturbofreak's Avatar
Baldturbofreak
Weird,
It looks like the piston and the valve are around the same if not THE same size. This means that they have similar area's.
If one has a turbo setup that has it's turbine's sized for the street, there will be more than a 2-1 ratio turbine/compressor pressure ratio.
So if there is 20 in the turbine and 10 in the intake how is it going to hold the gate shut against turbine flow? There is double the force(actually more,we are negating dynamic flow) coming from the valve than there is coming from the piston+ spring.
Granted these are observations based purely upon pics, but it seems to me from an engineering perspective that the design should have a much larger control piston.
I thought the rule of thumb was 2.2 times the area from control to valve.
Old Nov 9, 2006 | 05:22 PM
NICK YOSKIN
St. Jude Donor '08
U FU*CKIN DOG!
HOW THE WEATHER??????
ITS BAD AZZ DOWN THERE!
btw GIVE UR GIRL A STROKE FOR ME!
BACK HALF
Old Nov 9, 2006 | 05:23 PM
NICK YOSKIN
St. Jude Donor '08
Originally Posted by NAVY08
burn
BOB THAT WAS FUN!
Old Nov 9, 2006 | 06:39 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Hahaha, Nick... awesome. I agree, that seems overkill, but what part of your car isn't overkill already?
Old Nov 9, 2006 | 09:19 PM
NICK YOSKIN
St. Jude Donor '08
jay dont smoke to much.........hehehehehe
[IMG][/IMG
talk to soon
Old Nov 9, 2006 | 09:28 PM
NICK YOSKIN
St. Jude Donor '08
hey tony!
yeah now i was talking w/buddie, who is my engine guy, about L92
seriously though..i wanna get to the track a mroe and get the car to hook w/current.
T-BRAKE TOY COMMON SOON
Old Nov 20, 2006 | 07:55 PM
RoadRebel's Avatar
RoadRebel
New info in video format
http://videos.streetfire.net/categor...7800261cd3.htm
Old Nov 27, 2006 | 03:02 AM
George Scott's Avatar
George Scott
www.synapseengineering.com actually is registered on one of the other boards I use a lot and they have been answering a lot of questions regarding that new bypass valve they also mentioned in that video above.
I thought it was a 60mm gate though? In the video he mentions that it was a 50mm. TiAL should have their 60mm gate out by next spring.
Do you really need a bigger gate anyways?
-Nick
Old Nov 27, 2006 | 09:59 AM
JZ 97 SS 1500
-Nick
These gates have nothing to do with Synapse, and have been out for well over a year. We run them on the Salt flat diesels and now on rally cars. They are by far the best gate right now on the market. Tial's would not do the job.
To new gate
