Seat Harness
Old Nov 20, 2006 | 03:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Default Seat Harness
All of you drag guys, I am having a wolf 6pt roll cage installed. I will be keeping my sport seats and I want to know what type of seat harness is available and where to buy them from
Old Nov 20, 2006 | 03:49 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Brey Krause makes lap belt mounting hardware to allow you to leave your current seatbels and also use a 6 point harness.
It is easy to install.
Old Nov 20, 2006 | 05:06 PM
xlr8shn's Avatar
xlr8shn
Those brackets are the bomb!
Add some G-Force 5 point Harnesses from Summit, a wolfe sub belt bar and 4 removeable clips and you are good...
Old Nov 20, 2006 | 05:28 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Looks like some nice brackets!
Old Nov 20, 2006 | 07:33 PM
Wicked Weasel
they are good qualit, easy to install, and the proper way to wear a belt is forced with the bracket. Too many people install harnesses incorrectly and do more harm than good.
Old Nov 20, 2006 | 08:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
So where exactly can I get my hands on them Brey Krause brackets, who sells them, GotJuice? my mechanic likes them
Old Nov 20, 2006 | 08:15 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Here's mine, and I didn't use the above kit. Just mounted them to existing seatbelt bolts like the directions stated? Made my own mount for the crotch strap, and the Wolfe has the tabs on the bar for the shoulder belts. Passes tech at the strip.
Robert
Old Nov 20, 2006 | 08:19 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
If you find them, let me know I need a passenger and a driver for mine........Let me know how much and we can save on shipping
Old Nov 20, 2006 | 08:21 PM
MIKE-C5's Avatar
MIKE-C5
Default Brackets
Steve
They are 150.00 for the set, Im also thinking about the Fire Extinguisher mount for passenger seat, they also have Crow Harness like mine and Sparco.
Here is the link
http://www.livermoreperformance.com/...y.html#bk_fire
Old Nov 20, 2006 | 08:30 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by mikes99corvette
Steve
Here is the link
Mike, I got a Fire Extinguisher and mount coming ordered through the club last month waiting on the order to come in and then I will be set there
Old Nov 20, 2006 | 08:33 PM
NemesisC5's Avatar
NemesisC5
Do you have any pictures or links to view the Wolf 6 point cage?
Scotty
Old Nov 20, 2006 | 09:53 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Scotty
Scotty, I will post the link tomorrow as I do have it booked marked on my office computer and I have no pictures of the roll bar it is in my mechanics garage, I will get some during the install, Mike may have some as he has one in his car already
Old Nov 20, 2006 | 10:26 PM
RoadRebel's Avatar
RoadRebel
Peterpan,
Most of us with sport seats run the RJS camlocks and retain the stock seat belt. I get the rollbar wrap mount version that wraps the crossbar and we pull the 2 shoulder straps thru the hole in the middle of the seat. The lap belts anchor to the stock belt bolts and toss behind the seat when not in use. We do punch a hole in the floor thru the support to bolt in the crotch strap that tucks under the seat when not in use.
Infact, the 5 point will totally tuck away and you wont know its there.
Phil
Old Nov 20, 2006 | 11:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by RoadRebel
Peterpan,
Phil
Phil,
This sounds like what I really want to do retain the stock seat belt. Do those brackets work so I can keep the stock seat belt with the RJS camlocks?
Steve
Old Nov 20, 2006 | 11:40 PM
RoadRebel's Avatar
RoadRebel
Phil,
Steve
No need to buy those brackets. Just buy the RJS bar wrap and your good to go all the others have a bracket attached that will mound with the stock belt bolts . I suggest the top "Y" version as it only needs a single bar mount and Ys into 2. It easier and doesnt get tangled as much
Old Nov 21, 2006 | 12:53 AM
NemesisC5's Avatar
NemesisC5
Steve, I don't recall any posts of you tracking your car. Did the curiousity of what 742rwhp will do at the 1320 finally get to you ? Are you thinking about drivetrain upgrades as well, or how about CCW "Drag Pack". That rollcage really makes the statement that you are Goin For It!!
Scotty
Old Nov 21, 2006 | 01:03 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Scotty
Yup, I have been keep a low profile and need the cage as I am getting the itch now that I am used to driving around with this much power and the wife wants this safety equipment as I have scared the hell out of her on a couple of Hill country runs, yes saving up for the drivetrain upgrades and will keep the MN6, if you see what those boys are doing in Canada with this setup it puts I am really thinking of the Autocross or faster type of events, like what Joel runs in his Vortec setup, going 180+ is got to be fun and then you get to go fast for more than a few seconds at a time
To Seat Harness
Old Nov 21, 2006 | 07:44 AM
Wicked Weasel
look around for them by google. I forget who has them for the cheaper price. If I remember correctly some people have the lap mounts cheaper and others have the fire mount cheaper. I found a vendor where the combination with shipping was reasonable.
Old Nov 21, 2006 | 07:49 AM
Wicked Weasel
here is the install of the BK harness bar and the lap belt mounts...
http://forums.corvetteforum.com/show...ar&forum_id=23
Old Nov 21, 2006 | 07:53 AM
Wicked Weasel
Robert
Is your sub-belt mounted in front or behind you?
Also I see your top belts go around your seat not through it. I believe many HPDEs will not allow this set-up anymore. They are requiring that the belt goes through the seat from the top (so that it helps stop it from falling off your shoulders) and also that the belts are at the proper angle from the roll-bar over the shoulder (so that you dont crush your spine).
I also encourage all to get the HANS device. I know it is expensive and 1/4 mile guys rarely have a problem, but you never know when the HANS will help you.
