My engine build
Old Nov 20, 2006 | 04:26 PM
95BlueBomber's Avatar
95BlueBomber
Default My engine build
I just need a little direction on my engine build. Here is my idea... please critique
3.905 Bore
3.622 Stock Stroke
6.125 Rod Length
Rods- Eagle with ARP2000 bolts
Pistons- Mahle -9cc dish Forged
Crank- Stock LS6 crank
Cam- ECS Blower Custom Cam
Timing Chain- Double Roller from ECS as well
Heads- 243 cast Stage 5 heads- 66CC
**The heads will have to be milled .005 which should take them to 65cc
LS6 Intake
P&P throttle body
Induction/Power Adder- Vortech S Trim
I need opinions on the Mahle Piston versus the Diamond. Thanks guys!
Old Nov 20, 2006 | 04:52 PM
mdhmi's Avatar
mdhmi
Mahle by a mile. I spoke to multiple engine shops (that build for quality not price) and all of them recommended JE or Mahle.
Old Nov 20, 2006 | 05:00 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Between those choice I would vote MAHLE also and JE and WISECO also make excellent forged LSX pistons. Also, I am not implying that the DIAMONDS are junk but they are not the top of the line piston and are more of a budget buy that works well for most LSX f/i applications).
Old Nov 20, 2006 | 07:14 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
If the Mahles are 4032 i would throw them in the garbage-get the Diamonds. One small lean out and you'll be eating rings. I don't have any idea why anyone would want a 4032 piston versus a 2618.
Old Nov 20, 2006 | 07:31 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Also, isnt the 2618 "Preferred" for boosted/NOS applications??
Old Nov 20, 2006 | 08:00 PM
dads01dream's Avatar
dads01dream
Old Nov 20, 2006 | 09:11 PM
mean lx's Avatar
mean lx
Default JE's all the way
I personally would use JE out of the three.
Old Nov 21, 2006 | 09:15 AM
95BlueBomber
It was stated that the diamonds are a budget piston but they are more expensive than the mahles. You guys have me very confused now I can get the mahles much cheaper and they include rings and wrist pins. I guess my main question was do you all think that is a well rounded setup? Does it seem to be a good combo?
Old Nov 21, 2006 | 09:30 AM
willyfastz's Avatar
willyfastz
Yes that will be a very good setup, I use the Mahles in most all my builds. The Lunati rods cost a little more but are a little liter than the Eagle's.
Old Nov 21, 2006 | 09:42 AM
Phil97SVT's Avatar
Phil97SVT
I've always used diamond pistons in every build and have always been happy with them until the last set. The pistons had a significant weight variance between the heaviest and lightest but they switched them out without any question. They are in my 346 that has already gone 145mph on a soft tuneup and a weak bottle. When I build my big iron motor thats should make 1400hp or so I am going to use Diamond again.
Old Nov 21, 2006 | 05:37 PM
mean lx's Avatar
mean lx
Just 1400 hp...you're talking about to the rear wheels, right? Underachiever! James
Old Nov 21, 2006 | 06:00 PM
chriswtx's Avatar
chriswtx
Diamond here as well. They look just as good as my JE pistons...
Old Nov 21, 2006 | 06:08 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
3.905 Bore
3.622 Stock Stroke
6.125 Rod Length
LS6 Intake
P&P throttle body
SOUNDS GOOD.....
iam holding out for this.....................
Old Nov 21, 2006 | 10:53 PM
dads01dream
Your combo looks good.... Have you considered going with either an Eagle or Callie Dragonslayer crank? Just curious.
Wish ya the best with your combination!!! Can't wait to hear that bad boy fire up.
Old Nov 21, 2006 | 10:55 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Callie crank and rods here with diamonds.
Old Nov 21, 2006 | 11:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Im with Chris I have the Diamonds and no issues with 5200 boosted miles
Old Nov 21, 2006 | 11:22 PM
DJDL's Avatar
DJDL
If we are talking off the shelf, Wiseco is the best. I'll take my 1/16 ring stack over the metric stuff anyday.
To My engine build
Old Nov 21, 2006 | 11:29 PM
DJDL's Avatar
DJDL
3.905 Bore
3.622 Stock Stroke
6.125 Rod Length
LS6 Intake
P&P throttle body
I'd rather see wiseco pistons, callies ls1 rods (light rods) and patriot LS6 stgII heads or AFR 205's if you want to get the good ****
Old Nov 21, 2006 | 11:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
So far my diamonds work and same for the West Coast Heads and I know the eagle rods, 5200 miles and rocking on the motor, maybe next time I can go with the gold standard and upgrade the heads to the trick flow and those wiseco's and callies, as they seem to be about at the top of the performance parts for our builds
Old Nov 22, 2006 | 12:07 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Everyhting looks good EXCEPT the Mahles-pistons and rings together for a good price doesn't mean a good thing. Just stay away from the 4032 stuff and by no means are the Diamonds budget. Wiseco, Diamond, Ross are among the best stuff-if you WANTED the best you could get a set of CP pistons.
