winter=new motor
Old Nov 30, 2006 | 12:05 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default winter=new motor
well with the cold weather comin' ill be skeeming up my next move
build a 414 cid L96 with l96 heads and L76 intake?
use my Ls1 block and have darton wet sleeved to 427 cid?
build a 402 408 Ls2 with L96 heads and L76 intake?
build a 402 408 Ls2 with aftermarket heads?
can the new L96 heads handle high boost pressures...i like the aftermarkets with their thick decks. but do they flow like the L96????
give me your thoughts
Old Nov 30, 2006 | 12:12 PM
kromberg's Avatar
kromberg
You mean L-92 heads and block Interesting to see if the issues with the L-76 intake get resolved.
Keith
Old Nov 30, 2006 | 12:19 PM
NICK YOSKIN
St. Jude Donor '08
Keith
oups!!!
:o :o
what isssues?
Old Nov 30, 2006 | 12:20 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
With the kind of boost pressure you like to run, I would wait a bit and get the LSX ironblock + 6 bolts a head cylinder heads when they come to the market in early spring.
Then you'll have to back-half your car to handle the power.
Old Nov 30, 2006 | 12:23 PM
NICK YOSKIN
St. Jude Donor '08
thats another option....is that a tall deck though???
Old Nov 30, 2006 | 12:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thought there were two different heights being offered. 9.3 and 9.7 something.
Here is link.
http://www.gmgoodwrench.com/GMPerfor...6454&engCat=ls
Old Nov 30, 2006 | 12:31 PM
kromberg's Avatar
kromberg
oups!!!
:o :o
what isssues?
A lot have been failing a pressure test.
Keith
Old Nov 30, 2006 | 12:32 PM
NICK YOSKIN
St. Jude Donor '08
Keith
really hrmmmmmm
Old Nov 30, 2006 | 12:34 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
There are some issues with consistency of wall thickness on the L92 blocks - looks like GM has some toolling/process issues as the liners are shifting to one side during casting. Once that is worked out, it's a good platform.
However, since you are building now, my 2 cents goes to a re-sleeved LS2 (longer sleeves from"nickasil") or the new GMMP iron monster.
For a rototating assembly I'd stay with a 4" stroke, eagle crank, eagle rods and Wysco or JE pistons. CL-77 bearings, hellfire rings & mellings pump.
Thick deck heads are the way to go for high boost (above 15 lbs) and to maximize you'll want an LS7 style head - the only head manufacturer I am aware of that presently meets that criteria is ETP.
kromberg's Avatar
kromberg
really hrmmmmmm
They work ok for NA applications though from what I have heard
Keith
Old Nov 30, 2006 | 12:36 PM
Phil97SVT's Avatar
Phil97SVT
LS2 block
1/2" head studs
ARP main studs
Keyed, splayed, or dowel pinned main caps
Main cap support system
4.00" Callies crank
ETP LS7 heads
Old Nov 30, 2006 | 12:59 PM
NICK YOSKIN
St. Jude Donor '08
Originally Posted by Phil97SVT
LS2 block
1/2" head studs
ARP main studs
4.00" Callies crank
ETP LS7 heads
sounds good....LS7 intake?
link to main cap support?
thanks P
Old Nov 30, 2006 | 01:11 PM
NICK YOSKIN
St. Jude Donor '08
so it sounds like the LS7 style head is the way to go....thats now established..
next......
cannot go wrong w/LS2 block but when is the monster LSX big block available? price? when wil the heads be available and price too?
Old Nov 30, 2006 | 02:27 PM
Phil97SVT's Avatar
Phil97SVT
http://dmperformance.org/new/newpage.html
Old Nov 30, 2006 | 02:38 PM
AVB's Avatar
AVB
cool man... I see spare turbos in my future
Old Nov 30, 2006 | 02:43 PM
mdhmi's Avatar
mdhmi
The larger motor is probably a much better fit for the big turbos he got over the summer.
Old Nov 30, 2006 | 03:24 PM
NICK YOSKIN
St. Jude Donor '08
mark,
not sure that these turbos are too big for current cid..
if i go with larger motor then these turbos are gone too...
To winter=new motor
Old Nov 30, 2006 | 03:25 PM
NICK YOSKIN
St. Jude Donor '08
Old Nov 30, 2006 | 03:28 PM
AVB's Avatar
AVB
Hehe... just my way of keeping him from going too big
If I were to do it again, I'd go LS2, keep the 3.6" bore and do the L92's but that's me... For you Nick, those ETP LS7's look awfully good and I'd still go iron if you want it to live long above 1k hp/tq!! Unless, of course, this is an annual thing..
Arnel
Old Nov 30, 2006 | 03:32 PM
FreddyG's Avatar
FreddyG
LSx block is due out next spring and according to GM Tech magazine (GREAT article on it in this months issue), it'll have a street price of less than $2k. The block is standard bore of 4.125 and can take a stroke of up to 4.500" (tall deck version). Nice piece and cheaper than a WarHawk (the WarHawk is Al though). Good Luck!
