has anyone ever had a bad BAP. i ordered a KB BAP and a racetronix harness for my 04 Z06. the harness works fine without the BAP hooked up but as soon as i hook it up it start blowing fuses. i went over all my conections 10 times and everything is right. any input? if not i have to wait till monday to call KB.
I had one which was only a week old and started blowing out fuses too. I tested it and it was fried internally. I sent it back and they shipped me a new one and so far so good !
Check amp. draw they can only handle 12A. I had one in which the
BAP internal circuit breaker failed and the fuel pump would not run. Just
prior to that it blew its fuse a couple of times!!!
Please contact support@racetronix.com with all your contact info, the details of your problem and when it occurs.
