Winter upgrade
Old Dec 21, 2006 | 08:21 PM
Jeff65's Avatar
Jeff65
CF Senior Member
Default Winter upgrade
In August of this year i purchased a 2004 C5 with the intention of building a beast. I have taken the last couple of months and did as much research as I possibly could so that I could do everything at once and do it right the first time. I've listented to the arguments over tt's and sc's and finally I have decided to let Andy at A&A put it together for me.
403 CID Forged Short Block
Edelbrock Custom CNC Ported Cylinder Heads
A&A custom grind camshaft
T-Trim Supercharger
60lb injectors, in tank fuel pump, kb boost a pump
Dewitts high capacity radiator
Alky Control Methanol Injection System
FLP5 Transmission
3.42 Diff
2400 Stall Coverter
Ceramic coated American Racing Headers
For those of you that have something similiar what can I expect from the car. I want this car streetable but on the edge.
Old Dec 21, 2006 | 10:44 PM
mdhmi's Avatar
mdhmi
That's quite a mod list. Congrats.
Old Dec 27, 2006 | 12:21 AM
Jeff65's Avatar
Jeff65
CF Senior Member
The car is set to arrive at A & A Corvette Jan 8. Can't wait!
Old Dec 27, 2006 | 12:37 AM
2004SpiralGrey's Avatar
2004SpiralGrey
what fuel setup is andy putting in your car?
Old Dec 27, 2006 | 10:49 AM
Mike04's Avatar
Mike04
He has listed: 60lb injectors, in tank fuel pump, kb boost a pump.
That is not the norm for an 04 though.... Usually just the boost a pump is done due to having to drop the tank. However, I doubt that boost a pump alone will supply enough fuel for the kind of power he should make with that set up.
Old Dec 27, 2006 | 08:03 PM
Jeff65's Avatar
Jeff65
CF Senior Member
The only thing I did not opt for is a Fast 90mm Manifold with LS2 Throttle Body. Is this an investment that I should go ahead and make?
Old Dec 27, 2006 | 08:09 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
NICE!
Old Dec 28, 2006 | 12:18 AM
4DRUSH's Avatar
4DRUSH
Old Jan 7, 2007 | 12:12 AM
Jeff65's Avatar
Jeff65
CF Senior Member
Default Dropped the car off today
Dropped the car off today with Andy. Added Fast 90mm Manifold with LS2 Throttle Body, oil and tranny cooler and custom fuel system. New wheels and tires are in the works.
Old Jan 7, 2007 | 12:25 AM
4DRUSH's Avatar
4DRUSH
wow Good luck sleeping
Old Jan 7, 2007 | 12:43 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Congrats
A&A is a great guy and you will be 100% satisfied
To Winter upgrade
