Intakes, LS1, LS2, LS6, Fast
Old Dec 26, 2006 | 09:57 PM
JimmyZ78's Avatar
JimmyZ78
Default Intakes, LS1, LS2, LS6, Fast
What do you prefer and why? What are the pro's and con's of say the LS2-LS6 for F/I?
Old Dec 26, 2006 | 10:24 PM
mdhmi's Avatar
mdhmi
What size motor are you talking about? How big is the cam? How high are you going to rev the motor? Where in the power band do you desire to make power.
Your question can't be answered without knowing the answers to these questions first.
Old Dec 26, 2006 | 10:35 PM
Skunkworks's Avatar
Skunkworks
I have some flow numbers if it will help.
Old Dec 26, 2006 | 11:24 PM
chriswtx's Avatar
chriswtx
Old Dec 27, 2006 | 12:02 AM
Skunkworks's Avatar
Skunkworks
LS1 75mm TB
RPM__TQ__HP
2000 326.4 124.3
3000 364.2 208.0
4000 399.1 304.0
5000 428.6 408.0
6000 408.8 467.0
7000 366.6 488.6
LS6 75mm TB
RPM__TQ__HP
2000 332.2 126.5
3000 366.0 209.1
4000 402.9 306.9
5000 436.9 415.9
6000 421.4 481.4
7000 370.7 491.1
Weiand/LPE 75mm TB
RPM__TQ__HP
2000 325.3 123.9
3000 365.9 208.8
4000 405.2 308.6
5000 430.3 409.7
6000 400.9 458.0
7000 362.2 482.7
LS2 90mm TB
RPM__TQ__HP
2000 322.2 122.7
3000 366.8 209.5
4000 398.3 303.4
5000 428.5 407.9
6000 427.5 488.4
7000 373.6 497.9
FAST LS2 90mm TB
RPM__TQ__HP
2000 330.1 125.7
3000 364.8 208.4
4000 399.8 304.5
5000 439.2 418.1
6000 426.6 487.7
7000 387.8 517.0
Test engine LS6 with 236/241 cam
I'll dig up more info tommorow (actual flows).
Mike
Old Dec 27, 2006 | 06:37 AM
JimmyZ78's Avatar
JimmyZ78
I guess I should have been more specific sorry. Stock bottom end, APS TT, Turbo Grind cam, 317's. I'd like a good low end torque curve.
Old Dec 27, 2006 | 10:56 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I would do LS6 in your case
Old Dec 27, 2006 | 11:10 AM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
One of the Vette Mags did a whole intake manifold test, it had a black c4 427 wide body on the cover. IIRC LS6 on the tester LS2 did very well.
Old Dec 27, 2006 | 12:38 PM
mdhmi's Avatar
mdhmi
Here Here. Stock cubes and a mile cam I'd stick with the LS6 intake.
Old Dec 27, 2006 | 01:09 PM
Skunkworks's Avatar
Skunkworks
For the money the LS6 intake on stock cubes is hard to beat even though Ls2 can be had fairly cheap.
I still have not found good info on intake when used with FI or boost. The speed of sound changes as you add boost so does the mass (your density went up) so the resonant tuning method used in NA apps falls apart. What may work great for one person will not for others, as can be observed by varying opinions and results. In a all out applications (high boost) shorter less restrictive runners net you more then a nicely tuned intake. I don’t have LS1/6 results to confirm this but seen results on Fords.
Mike
Old Dec 27, 2006 | 01:58 PM
chriswtx's Avatar
chriswtx
I thought I saw Roadrebel post that he was getting good results out of the LS2 intake/90mm with FI motors...
Old Dec 27, 2006 | 02:00 PM
mdhmi's Avatar
mdhmi
There are several TTi Stage X cars running around with both stock and big cube motors with the LS2 intake manifold and ported 90 MM LS2 TB.
I kept my LS6 intake manifold and stock LS1 TB as I didn't feel the potential gains of an LS2 were justified on my conservative street combo.
Old Dec 27, 2006 | 02:04 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
yeah mark especially when boost can easily be increased electronically!
oh.....sd tuned of course.
Old Dec 27, 2006 | 02:10 PM
mdhmi's Avatar
mdhmi
Originally Posted by NICK YOSKIN
sd tuned of course.
I've been researching this topic for quite some time and just haven't been convinced that SD would complement my setup. If AEM made a plug and play unit for our cars or if BS3 implementation was much cleaner I might feel differently.
One of my goals for 07 is to have a separate MAF tune for bracket racing. I want to be able to stand on it at the line and run 11.51's all day long, as 11.50 is the point where a cage is required.
You don't have to run 9's just to have fun.
Old Dec 27, 2006 | 02:28 PM
stevieturbo's Avatar
stevieturbo
n/a test results dont mean anything when comparing to a forced induction setup.
Old Dec 27, 2006 | 02:50 PM
mdhmi's Avatar
mdhmi
Read my earlier post. Documented gains have been established with the LS2 intake manifold and ported LS2 90mm TB on multiple twin turbo cars.
There is a torque loss down low, but you pick up some power up stairs.
Old Dec 27, 2006 | 10:31 PM
JimmyZ78's Avatar
JimmyZ78
OK, well I bought a LS2 Intake and Tbody. Thanks for the info. A SC'd car here locally is making 640rwhp with a LS2 setup, stock bottom end. He just upgraded to a 402 with the same intake setup and we are awaiting dyno numbers.
To Intakes, LS1, LS2, LS6, Fast
Old Dec 27, 2006 | 11:08 PM
Vince99FRC's Avatar
Vince99FRC
Since he is going bigger he should have the LS2 intake ported..
Old Dec 28, 2006 | 10:22 AM
RoadRebel's Avatar
RoadRebel
No ported TBs here. I do a very simple cleanup on the intake manifold removing mold flash etc and bolt them together. Its it the best boosted manifold I have found and certainly a very cheap combination to boot!
Phil
Old Dec 28, 2006 | 11:42 AM
mystifiedworm's Avatar
0mystifiedworm
Former Vendor
with the man!!!
Chad
