** Official FI Owners Club **
#61
Former Vendor
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
01 Z06 Speedway White
A&A Procharger D1, 42lbs. Inj. Stock Mani's/cat's, straight pipes, Nitrous IC Cooling /Cryo2 Chambers, HKS SSQV, SPA & AEM Gauges
550 whp / 480 rwtq off the bottles @ 8psi
Brian
Brian
#70
Do you want the current FI setup or all of the ones that have been on my current car? I have pics of each 1 in my sig. All hp/tq #s are at the rear wheels.
The thing they have in common is that they were the first version of each and were all used with the same motor internals, heads, cam, etc..
346cid PTK TT 830/804*
346cid TTi Stage III 590/700
346cid GWP/A&A D1 S/C (layed down Rad with twin ICs). 630/550.
#72
St. Jude Donor '09
Might be easier to read the ATI group
Procharger Supercharger (ATI, A&A, ECS)
JSTAN - '97 A4, stock LS1, ATI Procharger 451rwhp / 418 rwtq
Drewstein - '99 FRC, 402, D1
redcycle13 - First generation Procharger, lg headers, 8lbs. 470rwhp/433rwtq
peter pan - A&A DS1C
C6 Z06 - 2000 coupe, 6spd, A&A ATI Procharger, 489 RWHP
jers98vet - ECS D1, stock shortblock, 317 heads, Cartek 2X cam, LT's, 10# boost, no meth, 592rwhp 527rwtq
ttboyvette - 01' vert, stock bottom, ECS D1SC
jonjon - F1R Procharger, 383 Stroker, Meth/Alky, 755rwhp 675 rwtq, 10.38@134
fastphil - '03 Z06, stock motor, stock exhaust, D1SC Procharger kit, 6lbs boost, MTI tune, 577 RWHP
johncbourg - A&A 6 rib D1SC w/ 4.10 pulley, ECS Dual Nozzle Meth Kit, LGM Longtube pros w/hi flo cats, B&B Bullets, Kenne Bell Boosta Pump, Thunder Racing Racetronix Harness, HPTuners PRo, 60# Mot. Injectors
Cliff99C5hardtop - '99 C5 hardtop, ECS D-1, ECS Dual Port Alky Kit, A&A Blower Cam, stock bottom end, stock heads, Stainless Works Headers....@585 rwhp
FRCBobby - 2000 Pewter FRC, M6, A&A Procharger Kit
clemsondave - '03 Z06, A&A P1SC Procharger, stock block, ECS Alky kit, LG lt headers, RPS clutch, 573rwhp/478 rwtq
marco383 - '98 MN6 coupe, C5R 427, LS7 heads and intake, F1C Procharger w/latest twin intercoolers. Many other upgrades. 773 RWHP @ 8 psi
CAracer - 2004 Z06, A&A Forged 348, P1SC Procharger, AFR heads,
blower cam, Boost a pump, 556 rwhp, 468 rwtq
ubsloandlo - '01 Z06, Procharger D1 HO kit, Bone stock except BB Bullets, Valve springs, Pushrods and Bap, 530rwhp / 450tq stock pump was failing up top
Pakisho - '02 Z06, D1SC w Cerra Turbo Kit FMIC, Built motor, ARP Studs, Cometic Gaskets, Patriot Heads, Blower Cam, Kooks Headers, High Flow cats, Cutouts, Alky Control Dual Nozzle Kit, Racetronix/60lb Injectors, BAP, Tial BOV, Reichard Racing "small" pulley, RPS Clutch/HD Output Shafts/DTE Brace/CCWs and NT01s, 606rwhp/520rwtq before the heads/cam/alky/smaller pulley
mikes99corvette - A&A D1SC Procharger, 383 Stroker, Methanol, 700+RWHP
jparr - ATI P1-SC / stock motor / 445 rwhp / 7psi
Brian@ICS Performance - 01 Z06, A&A Procharger D1, 42lbs Inj., stock Mani's/cat's, straight pipes, Nitrous IC Cooling /Cryo2 Chambers, HKS SSQV, SPA & AEM Gauges, 550 whp / 480 rwtq off the bottles @ 8psi
jpm71 - Procharger D1SC with A&A bracket, A&A forged 402 shortblock, Patriot Heads, 4.25 pulley, ECS fuel system, RPM Trans, 714rwhp / 669rwtq mustang dyno
Whiteonrice - '02 Coupe, Procharger A&A, tune, otherwise stock, 473 rwhp 439 torque
#74
1 Post
St. Jude Donor '03-'06-'07-'08
427 C5R, STS twin turbos - larger size/ceramic coated, TH400 full manual with transbrake, installed by ECS. VERY VERY FAST. Track time in February. Looking to change my avatar.
#76
Oldtimer
1998 Arctic White Coupe w/pearl red ghost flames
Magna Charger w/3.3 underdrive pulley
Thunder Racing blower cam
Grizzly long tube headers and x-pipe
Random Technology low restriction cats
B&B Bullets
Be Cool radiator
Vortex Ram Air w/Power Duct
B&M Ripper shifter
Z06 clutch
MotorCity high-rise hood
EradiSpeed rotors
Goodridge stainless steel brake lines
WCC chrome split 5-spoke wheels w/Pirelli PZero Rosso tires
459 rwhp/427 rwtq
B&B Bullets
Be Cool radiator
B&M Ripper shifter
Z06 clutch
EradiSpeed rotors
459 rwhp/427 rwtq
#79
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Sign me up:
ECS complete D1SC blower kit with 60 lb injectors, on bone stock LS6 motor running ECS alky kit (for safety not power)-615 rwhp and 513 rwtq on 10lbs of boost!
