Another Textralia GP?
Old Jan 23, 2007 | 07:48 AM
jkz06's Avatar
jkz06
Default Another Textralia GP?
Did I hear a rumor that there was going to be another GP on these or is it just wishful thinking?
Old Jan 23, 2007 | 10:51 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
saw one in the parts section, brand new $900 plus shipping
Old Jan 23, 2007 | 10:53 PM
keith954's Avatar
keith954
http://forums.corvetteforum.com/show....php?t=1606140 hope it helps
Old Jan 24, 2007 | 11:31 AM
jkz06's Avatar
jkz06
Originally Posted by keith954
Thanks for the help, it's guys like you that keep me addicted to this forum. I broke down and bought a new one yesterday.
Old Jan 24, 2007 | 05:57 PM
keith954's Avatar
keith954
Old Jan 24, 2007 | 06:36 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We are presently at $979 shipped in the US, if enough people get together I might be able to persuade them to do another one. The last one did work out very well.
Old Jan 24, 2007 | 06:56 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Doug, what is included with the Clutch? 18lbs steel wheel? Didnt Textralia provided the new slave cylinder with OZ700 when they first came out? I heard you dont get a new slave cylinder anymore?
Old Jan 24, 2007 | 09:58 PM
z0quick's Avatar
z0quick
What would the GP price be? Google search comes up in the range of $960-990 to buy outright with free shipping. If we can get at GP at 900 or below that would catch my interest
Old Jan 25, 2007 | 03:46 PM
victoryracing's Avatar
victoryracing
Textralia doesn't not include the slave cylinder anymore. You can add it for $100.00.
Old Jan 25, 2007 | 08:53 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
I'd be up for a GP, but I need the aluminum flywheel.
Old Jan 26, 2007 | 01:43 AM
Textralia's Avatar
0Textralia
Former Vendor
We stopped including slaves and pilot bearings in our kits as a standard item. The reason for this was a simple one. Folks were destroying their cranks trying to remove pilot bearing without the proper tools and not following the proper procedure. The fact was the bearing was there, so as long as the y had it, they were determined to swap it. Even if the old one was fine.
The slaves are no longer standard because we were spending hours every day trying to help someone bleed their hydraulics because they didn't follow the proper procedure for bleeding the system.
Its not that we don't offer them. We still offer those items, as an option. We just removed them from the base kit, and made them an option. As a result, we dropped the price of the kit $100.
We're currently working on a few items for the C5's. We have custom built fittings so we can replace the factory line and quick connect and route the supply line where ever you want to. We may supply a slave with custom fittings, custom line, and a remote bleeder if folks are interested in that sort of setup. It would allow you to re-route the lines to keep them away from heat sources, and make bleeding a simple operation.
As for a GP... We're listening....
Old Jan 26, 2007 | 11:27 AM
FactoryRaceCar
Well I would DEFINATELY be interested in
When is this new stuff coming out?
Also, what flywheel comes standard with the 0Z700? What is recommended for F/I Steel or Aluminum?
Old Jan 26, 2007 | 01:48 PM
95BlueBomber's Avatar
95BlueBomber
You can count me in a GP but I would want the remote bleeder with this. Is your alls bleeder a one way valve type?
Old Jan 26, 2007 | 02:43 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I will soon be in need of a new clutch (maybe twin) so I am all about the gp. Don't need the remote bleeder as I already have one in but the rest sounds great as well as a lighter flywheel. BTW, I currently have an unused and balanced Fidenza alum flywheel---would it work with the twin?
Old Jan 26, 2007 | 03:55 PM
stevieturbo's Avatar
stevieturbo
If a GP means I can get a twin for say half price...Im in
no harm in trying lol
Old Jan 26, 2007 | 04:29 PM
ttboyvette's Avatar
ttboyvette
I have a 2001 LS1. I am installing a OZ700 single disk with the steel flywheel, will I need to replace the slave cylinder?? Or will I be ok. My car has 16,000.
Tom
Old Jan 26, 2007 | 04:45 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Would adding extra length to the lines cause any noticable difference in hydraulic action? With my turbos in the car it's sometimes a little hard to reach the quick disconnect with the disconnect tool. If the disconnect were further up the frame rail or near the brake reservoir it would be a lot easier to reach. I would definitely buy a modified cylinder setup next time I do a clutch job if it made servicability easier.
To Another Textralia GP?
Old Jan 27, 2007 | 01:22 AM
Scubanme's Avatar
Scubanme
I'm interested in a setup with a bleeder.
Old Jan 29, 2007 | 01:28 PM
kaizenz06's Avatar
kaizenz06
I need a clutch and will be interested in a GP if it happens soon!
Old Jan 29, 2007 | 01:52 PM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I have an e-mail into them now. As soon as I get any info I will let you guys know.
