Twin 76's
Old Feb 14, 2007 | 02:56 AM
juiced's Avatar
juiced
Default Twin 76's
Anyone running twin 76's on the HP twin kit or any other similar setup with a 408?
I'm trying to get an idea of where spool might be at.
how would twin 67/70's spool on a 408 this being with .96 t4 housings....
Old Feb 14, 2007 | 08:06 AM
chuntington101's Avatar
chuntington101
have a word with Mr Big on here. he is running the HP kit with bigger turbos (dont think hes gone for the 76's).
also speack to Nick Yoskin. hes got the PTK/S kit and is running T66's. also do a search for PTS and speack to Arnel (sorry cant remeber his username on here). he is running a 408 with bigger turbos.
thanks Chris.
Old Feb 14, 2007 | 09:22 AM
SR71's Avatar
SR71
I had twin non bb turbonetics t76's from forced inductions with mps exhaust wheels and .68 ar's on my 402. boost started at ~ 3200 and full boost(15psi) was in by ~ 4200. this was with a 246/240-614/588-114 cam.
Old Feb 14, 2007 | 10:09 AM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
HELLO,
i run 347 w/turbonetic's 66mm ceramic bearing and the housing is .68
definately an aggressive turbo for 347 but surprisinly it spools almost as quick as my old te44 from a dig. now from any kinda roll the spool delay isnt there, load. as far as power compaired to the te44 it isnt close.
arnel runs same turbos on his 408 but his housings i believe ar .81
he too will tell you that spool isnt an issue. screen name is AVB
OH BTW I TOO BOUGHT MY TURBOS FROM JOSE @ FORCED INDUCTIONS ALONG SR71 AND AVB ......
Old Feb 14, 2007 | 11:08 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
I have twin 67MM turbos with that kit, and the dyno graph posted here on the forum in FI, just do a search.
As far as 76mm... corvette4ever has that set up with a 427. He has run at 6psi and 11psi and can answer those questions for you.
Old Feb 14, 2007 | 12:03 PM
juiced's Avatar
juiced
Thanks Guys....
Old Feb 14, 2007 | 01:16 PM
AVB's Avatar
AVB
408, Twin 66's w/ .81's here and like Nick said above, boost lag is not an issue at all and is IMO ideal. I haven't put it on a dyno since moving to the 66's so I couldn't tell you specific rpm info. just yet.
IMO, the 67's on a 408 is a nicer match
Arnel
Old Feb 14, 2007 | 02:44 PM
blackbelt's Avatar
blackbelt
ALex your not cool enough to have turbos that big.
Old Feb 14, 2007 | 03:42 PM
Corvette4ever's Avatar
Corvette4ever
http://forums.corvetteforum.com/show....php?t=1624435
Old Feb 14, 2007 | 03:50 PM
juiced's Avatar
juiced
Yeah well the S95 won't fit anywhere so i have to figure out something else....
Old Feb 15, 2007 | 06:45 PM
SR71's Avatar
SR71
Arnel
66's are small on a 408. sure they spool quick, but they run out of breath quick too. if you are wanting to make ~ 1000hp, they are out of their best effiency range. staying close to max effiency is the reason some(like me) made BIG power with less boost. how many others here ran 5.5x @ 128 mph in the 1/8th on only 15psi??? sure paul z ran 5.48 @ 125 mph with a 347 and 67's. but that was with what??? 22-24psi and a mega $$$ set-up??? if you want to make big power, you can't be afraid to run big turbos. if you can be satisfied with mediocre power, stick with undersized, instant spooling turbos. while they may feel fast, they will ultimately be slower than a properly sized turbo.
Old Feb 16, 2007 | 12:18 AM
AVB's Avatar
AVB
Not on a 408 used primarily on twisties... although I'm definitely a fan of going big
If I seriously weren't horsing around and wanted to compete at the dragstrip, had what it took to put it down and keep it together (goal being max effort), I totally agree... 66's are small and wouldn't even be considered. Otherwise, as some are doing here, when going to the track the boost is run at the lower setting and that's just to keep traction in check.
Old Feb 16, 2007 | 02:08 AM
Red C5's Avatar
Red C5
Twin 76s probably wouldn't reach full boost before 4500 rpm maybe closer to 5000 with such a large AR. Depending on what you are trying to do, that's probably way too much turbo for you. They will make 1800bhp.
Old Feb 16, 2007 | 03:32 AM
SR71's Avatar
SR71
turbos are most efficient at 50-60% of max flow.
Old Feb 16, 2007 | 10:33 AM
NICK YOSKIN
St. Jude Donor '08
so tom ur saying that my 66mm ar.68 are to small for my 347?
when i bought them i was worried that they
were going to be to much of a step up from my punnie 57mm te44.
that certainly wasnt the case, these bitches are insane! but did i leave power on the table?
paul z motor wasnt anything special at all.
Old Feb 16, 2007 | 02:03 PM
AVB's Avatar
AVB
I think he meant on a 408 they'd be small Nick. Although it'd be interesting what some 76's would do with the smallest exhaust housings on your motor..
Arnel
Old Feb 16, 2007 | 02:31 PM
NICK YOSKIN
St. Jude Donor '08
Arnel
not sure thats what he meant arnel, he was referring to paul's z car...
to small the 67mm....
To Twin 76's
Old Feb 16, 2007 | 08:59 PM
SR71's Avatar
SR71
no....66-67's are great for a 347.
and there wasn't anything in paul z's car that wasn't special.
Old Feb 16, 2007 | 09:44 PM
NICK YOSKIN
St. Jude Donor '08
yeah tom they feel ALOT stronger then old te44, 57mm. thats why i was a little dissapionted when i went to the track w/66 and it didnt mph much faster. lessoned learned extra power doesnt always equate to lower et or more mph. reason big wheel spin
i not sure about that...engine wise, LS6 head certainly dont fall into the catergory of "special"
Old Feb 21, 2007 | 09:05 AM
BiggieO's Avatar
BiggieO
1st Gear
I dont hav a corvette,but im running twin t76..406 sbc,n they spool around 3200rpms also...Real fast
