O2 Sensor codes
Old Mar 9, 2007 | 10:49 AM
clemsondave's Avatar
clemsondave
Default O2 Sensor codes
I am constantly getting O2 sensor codes. Could the sensor be bad, or is this just a fact of live with headers and FI?
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
Old Mar 9, 2007 | 12:17 PM
HP_Addict's Avatar
HP_Addict
I get those codes with my headers, I just ignore them.
Old Mar 9, 2007 | 01:18 PM
Rob's 73's Avatar
Rob's 73
When I had stock manifolds and borla stingers = no codes
Added LGM LT's = codes
Went back to Titanium exhaust and LGM LT's = no codes
That tells me that there less back pressure with the borlas which doesn't help with heating up the O2 sensors.
Old Mar 9, 2007 | 02:43 PM
rudolph schenker's Avatar
rudolph schenker
If the check engine light bothers you and those codes always come up. I found the best way is to delete them with some tuning software. I used the ls1 edit. This way no check engine light and I still pass emissions!
Old Mar 9, 2007 | 03:48 PM
clemsondave
Cool, I will give that a shot. Only bothers me when I am screaming down the strip and the check engine lights up
Old Mar 11, 2007 | 04:41 PM
CliffB-99's Avatar
CliffB-99
3 options
1) Program them out
2) Switch to 02 simulators instead of sensors
3) Ignore check engine light.
I chose option 1, because I didn't want to get used to the check engine light being on, and then possibly ignore a more serious problem unknowingly.
To O2 Sensor codes
