Meth.
Old Mar 28, 2007 | 01:22 AM
PhatNick's Avatar
PhatNick
Cruising
Default Meth.
How much hp could I see if I used a snow meth injection on a 383 n/a with 11.50/1 compression? The reasson for doing so is to see if the lower IAT's would help that much. Plus I will be looking for my next power adder like a Procharger or ECS' kit.
Old Mar 28, 2007 | 07:39 AM
Mike04's Avatar
Mike04
I would look into the Alky Control kit sold by ECS. I added a dual knozzle kit to my SC stock motor and gained about 40 rwhp through the ability to add more timing. I'm seting at about 530rwhp.
Old Mar 28, 2007 | 11:11 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Here are my thoughts on Meth...
Meth/alky is used to keep detonation away, not to add anymore power. If all things are kept constant...alky will hurt HP.
The thought then becomes, well now i can add more boost, or more timing..run a little leaner. That is good, but when you do those things, have you actually made anything safer than what it was?
Example
I run 11.5 AF / 14* of timing / and 7lbs and make 698 RWHP using nothing but 98 octane gas, should be pretty safe.
Well now i just add alky... and change nothing else....i get 680 RWHP and a with the same 11.5 AFR
Since i added the alky, i can now run 12.5 afr / 20* of timing and make 725 RWHP... on the same 7lbs.
Did i really make the car any more safe by using Meth???
BTW, the are numbers in my head, not my actual numbers.
To Meth.
