Two Inline Fuel Pumps
Old Mar 28, 2007 | 11:54 PM
CrazyChris's Avatar
CrazyChris
Default Two Inline Fuel Pumps
There have been quite a few threads on fuel lately, so why not one more
Is there anyone who has removed the intake pump setup and replaced with a pickup and bulkhead fitting that has two 255 inline pumps as feed then run a FPR and return back to the tank?
It is a proven setup on other high hp cars. Why would this not work on a C5 as well?
Old Mar 29, 2007 | 03:49 AM
2MuchRiceMakesMeSick's Avatar
are you talking about one pump in each tank?
its an interesting idea
Old Mar 29, 2007 | 05:44 AM
1a-play's Avatar
1a-play
I removed the stock lines and silver brazed some tubes/8a 6an fitting to the tank cover- seems to be doing fine- kept the level sensor in place though
Old Mar 29, 2007 | 09:26 AM
CrazyChris's Avatar
CrazyChris
No, remove the stock pump from the driver side tank and then run 2 external inline pumps.
Old Mar 29, 2007 | 09:44 AM
Emuffinman1's Avatar
Emuffinman1
I took out the stock pump and put in two walbro pumps using a "y" to merge, to stock tube. It feeds 768 RWHP. Also, I run a Kenne Bell boost a pump. (8an lines with Fast fuel rails, etc.)
Old Mar 29, 2007 | 03:52 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 29, 2007 | 06:17 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Do you mean two inline pumps run in serial, or two inline pumps run in parallel?
I think the APS fuel kit runs two inline pumps in parallel. And for what it's worth, the ECS fuel kit can run the same way, you just have to plumb it differently. When I bought my kit it even came with enough hose that I didn't have to buy extra to run mine in parallel.
Oh, and I wouldn't just remove or disable the OEM system. It runs the tank to tank transfer venturi pump. If you come up with an alternate method of moving fuel between tanks, make sure that the passenger side drains first or you'll get a CEL code that will cause your gas gauge to show the car is empty. The PCM expects to see the passenger tank with less fuel than the driver tank or it thinks that the in tank fuel level senders are busted.
Old Mar 30, 2007 | 01:03 AM
CrazyChris's Avatar
CrazyChris
Thanks for the reply. I was thinking in parallel. If the driver side fuel pump bucket is removed, why would that keep the passenger side from transferring to the driver side tank?
Old Mar 30, 2007 | 01:21 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I assumed that by your description (twin pumps running through a bulkhead fitting) that meant you were going to plumb AN -- likely #8 or bigger -- and bypass the OEM stuff. No matter how you do it, just make sure the OEM feed lines are seeing pressure or you'll interrupt the tank to tank transfer mechanism.
Old Mar 30, 2007 | 02:16 AM
CrazyChris's Avatar
CrazyChris
You assumed correctly. Plumb bigger lines, bypassing the OEM stuff. I must be missing a step because I fail to see how the OEM feed line drives the tank to tank transfer.
Old Mar 30, 2007 | 08:53 AM
AustinL911's Avatar
AustinL911
Check out this post for details on the split tanks...
http://forums.corvetteforum.com/show....php?t=1663527
Old Mar 30, 2007 | 10:18 AM
CrazyChris's Avatar
CrazyChris
Does that hold true for the older style systems? Is the teed line from the feed line over to the passenger tank present in all the OEM designs?
Old Mar 30, 2007 | 10:20 AM
Mustang Fan's Avatar
Mustang Fan
I have a set of twin 255s with a Y-block, lines and a bunch of fittings if you are interested. Sent me a pm
To Two Inline Fuel Pumps
