PTK Oil Drain
Old Apr 27, 2007 | 04:06 PM
2MuchRiceMakesMeSick's Avatar
Default PTK Oil Drain
For guys with the PTK kit...Where are you putting your oil drain lines?
these pictures are with the fbody oil pan my motor came with
Old Apr 27, 2007 | 04:09 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
don't know where they go, but that motor sure looks pretty
Why the F-body oil pan?
Old Apr 27, 2007 | 04:24 PM
its a long story but basically i saved a bunch of money by switching to gieco...err getting this motor (which was setup for a fbody)
I know I still need the "bat style" oil pan but im curious where the rest of you PTK guys are putting your return lines. Pics would be great!
Old Apr 27, 2007 | 07:40 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
justin,
hope this helps
http://i22.photobucket.com/albums/b3...9/IMG_1814.jpg
http://i22.photobucket.com/albums/b3...9/IMG_1817.jpg
Old Apr 27, 2007 | 08:18 PM
jkz06's Avatar
jkz06
It sure is nice having a guy that has torn down and rebuilt his PTK more times than I'm sure he can count a keyboard away.
Old Apr 27, 2007 | 11:15 PM
tazinhawaii's Avatar
tazinhawaii
Where are the oil pan kick outs?? I took off the lower oil pan cover and drilled two holes (one on each side) facing upwards. That was the only place I could see putting them without pulling the motor. Since your motor is out, towards the back is what I suggest just because of clearances with the motor installed.
Derrick
Old Apr 28, 2007 | 09:29 AM
NICK YOSKIN
St. Jude Donor '08
s'up Jeff?
maybe ill tear it apart again soon......
347 getting boring...
427 sounds better anyway....
Old Apr 28, 2007 | 05:14 PM
jkz06's Avatar
jkz06
Originally Posted by NICK YOSKIN
s'up Jeff?
Sounds good to me. You do it first so when I'm ready you can give me all the tips on that set up too.
Old Jun 29, 2007 | 12:15 AM
Derrick
Thats a fbody oil pan. I recently drilled them out on my z06 pan.
My friend is going to weld them in as soon as UPS delivers the aluminum fittings
Ill get some pics up soon
Old Jun 29, 2007 | 12:18 AM
These are actually where i drilled them
To PTK Oil Drain
