FI and Sparkplugs??
Old May 4, 2007 | 12:10 PM
SpeedyD's Avatar
SpeedyD
Default FI and Sparkplugs??
You guys out there with SC's or TT's, what sparkplugs are you running and what are you gapping them at? I figure I will be bossting about 12lbs max. Do you have to reduce gap because of the extra air flow?
Thanks, Dan
Old May 4, 2007 | 12:32 PM
Mike04's Avatar
Mike04
Thanks, Dan
NGK TR6 .035 gap
Old May 4, 2007 | 05:24 PM
SpeedyD's Avatar
SpeedyD
Originally Posted by Mike04
NGK TR6 .035 gap
thanks Mike, nobody else?
Old May 4, 2007 | 05:43 PM
MotleyDrew's Avatar
MotleyDrew
tr6 35 gap as well
Old May 4, 2007 | 05:55 PM
chriswtx's Avatar
chriswtx
same here...
Old May 4, 2007 | 06:09 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Another TR6 gapped .035
Old May 4, 2007 | 06:26 PM
2MuchRiceMakesMeSick's Avatar
same as everybody else...tr6 @ .35 gap
Old May 4, 2007 | 06:29 PM
SpeedyD's Avatar
SpeedyD
I had already picked up the TR6's but I saw another thread started on the TR55i's and a 50 - 55 gap. Thought that was a little big but just wanted to get a general idea what the FI crowd was running! thanks guys!!
Old May 4, 2007 | 08:57 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
TR6 gapped at .024 for turbo cars.
Old May 4, 2007 | 09:48 PM
leojnknsC5's Avatar
leojnknsC5
AC Delco R42lts @ .035"
Autolite 104
Autolite 103 for the track only.
Old May 4, 2007 | 09:50 PM
leojnknsC5's Avatar
leojnknsC5
TR55 is the stock heat range and .050 gap is too big unless your running MSD's new higher output coils. They say you can run .050" on them.
Old May 4, 2007 | 11:51 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Want to know as well since the installation will be next Friday
Do y'all have part number for TR6 0.35" or anyone from Autozone should know it?
-Mike
Old May 5, 2007 | 03:40 AM
Showdown's Avatar
Showdown
parts person at autozone would Know. NGK TR6. Do not get NGK TR55 plugs. they are not the same. GOOD LUCK.
Old May 5, 2007 | 07:24 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
pn is TR6, no go on autozone, advance or napa, post #9 for gap
Old May 5, 2007 | 07:50 AM
200MPH's Avatar
200MPH
Part # for tr6 is 4177.
Old May 5, 2007 | 08:13 AM
c52k1vert's Avatar
c52k1vert
916/795 rwhp C5R 412 YSI
I run.... NGK R5724-8 Stock No. 7317 Gap .028
Other options depending on your need are:
(one step colder)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Motorcraft AWSF-22C (copper); Autolite 103; Denso IT-20 (stock number 5326)
(two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT-22 (stock number 5327)
(two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
(three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
(four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
Old May 5, 2007 | 09:03 AM
SpeedyD's Avatar
SpeedyD
Thanks for all the info guys!!! i really aprreciate it!! Looks like I should be firing my car up today, wish me luck!! Thanks, Dan
To FI and Sparkplugs??
Old May 7, 2007 | 02:04 PM
jbuerke142's Avatar
jbuerke142
NGK TR6 .035 gap
+1
Old May 7, 2007 | 04:23 PM
SteveDoten's Avatar
SteveDoten
Dan, don't bring the car to Don with those 20's, do have a set of DR's?
Old May 7, 2007 | 04:39 PM
SpeedyD's Avatar
SpeedyD
Oh YEAH! DR's will be on the car before tunning. Those are just to look pretty!
