Best High Temp Paint
Old May 11, 2007 | 12:07 PM
2MuchRiceMakesMeSick's Avatar
Default Best High Temp Paint
Who makes the best high temp paint?
Old May 11, 2007 | 01:43 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I've used the VHT "Engine Paint"
It works great. You just have to make sure that you bake the part at 250* for 1 hour. If not, its not hardened.
Old May 11, 2007 | 01:49 PM
right now im looking at options on my swaintech coated ptk hot parts. I dont really car for the white.
Old May 11, 2007 | 02:42 PM
AVB's Avatar
AVB
I use ThermoTec High-Heat Coating in silver.. that and same thing under the DEI brand can handle 2000* and are made to coat header wraps.
Arnel
Old May 11, 2007 | 07:17 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
JMHO, but I think the quality and durability of your paintwork will largely be determined by your prep work and not so much by which paint you use. I mean sure, there's crappy paint out there, but I've had even regular paint from Discount Auto last a long time on parts that were properly degreased and blasted.
Old May 11, 2007 | 07:24 PM
well they are already coated by swaintech in bright WHITE
Im just looking to change the color to black
Old May 11, 2007 | 07:58 PM
dwspas's Avatar
dwspas
Alsa Corp. has the best high temp paint out there.
alsacorp.com
Old May 11, 2007 | 08:22 PM
AlwaysInBoost's Avatar
AlwaysInBoost
prep work is KEY when it comes to how long the paint will last and how well it looks.
Old May 11, 2007 | 08:37 PM
AustinL911's Avatar
AustinL911
I'd send it to that powdercoating guy that Nick Y. sent his too. Powdercoating is more durable than paint anyways. Nick's turned out great.
Old May 12, 2007 | 06:05 PM
Tomulrich's Avatar
Tomulrich
Nick Yoskin didnt send his to a powder coater......his are painted! He painted over the Swain Tech coating
Hirsh makes a 2000 degree paint that guys have used over swain tech with no problems.....This is what I am using on my swain coated headers.
This is the highest heat rated paint I know of...
Tom Ulrich
Old May 12, 2007 | 06:11 PM
AustinL911's Avatar
AustinL911
Tom Ulrich
Hmmm. Nick told me he was going to have his powdercoated. Something must have changed. Anyways, I still think I'm going to have mine powdercoated.
Old May 12, 2007 | 06:52 PM
Warp Factor's Avatar
Warp Factor
This will sound tacky and I've never tried it on top of a "Jet Hot" type coating, but after trying a number of header paints, the thing that held up the best is regular old barbecue paint. Rustoleum or Red Devil, available almost anywhere. Even stuck pretty well over chrome. Have only tried black.
Old May 12, 2007 | 07:05 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Tom Ulrich
tom tom tom.............no!
i had it powder coated!
bad tom!
its holding up very nicely!
Old May 12, 2007 | 07:33 PM
AustinL911's Avatar
AustinL911
After reading this again, I think you might be thinking of Kevin S. (Shinobi Z). I believe he used this paint you speak of.
Old May 12, 2007 | 08:14 PM
Tomulrich's Avatar
Tomulrich
...sorry Nick...I thought you told me you painted them.
Let me ask you this......do you think if you had the Swain tech coating powder coated with a high luster silver....do you think it would still be shiny...even though it is over a rough surface.
Did your powder coater feel that coating over the Swain tech was going to be problem free (knowing that powder coating works on opposite charges attracting and Swains ceramic coating cant hold a charge because it is not metal) ...
I am lookind to get a high luster over my Swaintech coating...I want the bling bling factor also....I bought the Hirsch 2000 degree high temp , high luster aluminum paint..
I even thought about chroming over the Swain tech ...but told this could not be done...also due to its roughness I dont think it would shine...
Please Nick...and everyone else if you have helpful input....please post it..
Thanks Tom
Old May 12, 2007 | 08:37 PM
tom i really dont think you can keep the hot parts shiny for very long. that is why so many, including myself, paint the hot parts black
Old May 12, 2007 | 09:07 PM
NICK YOSKIN
St. Jude Donor '08
Thanks Tom
tom not a problem...
my powder coater tells me all hi temp colors are only available in flat colors.
To Best High Temp Paint
