Nitrous Help Please!!
Old May 12, 2007 | 11:05 AM
RIP1976's Avatar
RIP1976
Default Nitrous Help Please!!
Ok here is my setup Nitrous Express Hitman with fuel pressure safety switch "set at factory setting out of the box" , Nitrous Express TPS Switch and a MSD Digital Window Box. Now here is my problem.
With everything wired up negative to the MSD and positive to the relay fired by the TPS the fuel solinoid will not fire. The nitrous will though.
Does anyone have any ideals on wth is going on????
Do I need to wire up a relay inline with the negative output of the MSD its suppost to handle a 4.5 volt draw.
Old May 12, 2007 | 05:44 PM
RIP1976's Avatar
RIP1976
WEll I never found a real problem that was causing this but I did find a fix. I wired a negative triggering relay into each of the solinoids and they are both working fine now.
