I have a 2004 Z06.... Bassani TriY headers and Street Comp exhaust, Vinci 055 accelerated lift cam, AFR 205 61cc Mongoose heads, Crane 1.8 accelerated lift rockers, Crane 833 extreme duty springs, blueprinted oil pump, Shaner ported throttle body, double roller timing chain, Blackwing intake with a power duct and Haltech tunnel port grill, Textralia OZ700 clutch w/billet flywheel C6 Z06 shifter and QA1 shocks.
I have pretty much decided on NX as the brand of nitrous kit I would like however I am not sure which of the kits is the best. Of course I will be getting all the accessories (GenIII heater,fpsw,window,purge etc). I am looking at running a 100 shot but don't want to rule out a little more. The car is mostly street driven but I go to several track nights as well. Which is the better kit? basic kit, single MAF kit or the LS1 MAF kit? http://www.nitrousexpress.com/Pages/GMmain.htm
Thanks!
you cannt run a maf kit without cutting up your stocker. i would go with nitro daves plate kit.
I thought one of the maf kit options didn't require tearing up the original maf?? Somebody must be using one of the maf kits and have some comments....please.
I have always heard good things about the base kit as well but I would think the maf kits mix the fuel and N20 better.
