This Is It! Promise!
Old Jun 20, 2007 | 05:27 PM
  #41
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by RoadRebel
Nope, not trying to be a dick at all..
But..are you really really sure your going to stick with it?
Do you have a spare laying around?
Phil
spoke with tech over at earls and they assured me that their cooler will not cause any restriction. that POS tube fin that i had on was more restrictive then this earls thats for sure...all those bars that make up the cooler will out flow that single tube.
actually phil had two people pm asking why you were being dick to me......
i told them your just that way....
Old Jun 20, 2007 | 07:26 PM
  #42
tensecvet's Avatar
tensecvet
Originally Posted by NICK YOSKIN
man if i stuffed into your chassis
Your going to need it , with that kind of power my friend. i'm sure you know that.
thanks for the R&D your doing, someday ................
Old Jun 20, 2007 | 07:27 PM
  #43
RoadRebel's Avatar
RoadRebel
Nope, not being a dick at all! Just trying to get you to really think about your decision and why it may be wrong . To much spoon feeding these days .
In fact, maybe you can call your tranny builder, I'm sure he will give you the correct answer .
Phil
PS A good tube and fine has virtually zero restriction (minus frictional losses) as its a tube only so not sure how a bar and plate could flow better. But its not the point I am after anyways.
Old Jun 20, 2007 | 09:45 PM
  #44
NICK YOSKIN
St. Jude Donor '08
Phil
i agree with yoo 100% on the spoon feed deal.....you hold me at a higher standard and expect the best.."man that sounded good"
phil i take it as a complament
as a matter of fact i was talking with todd......just wanted to see how his car was coming along and other small talk. he told be that rodney perfers to use tube vrs bar and plate as believe the on paticular unit that they had was causing resistance..other then that he didnt mention anything else.
Old Jun 20, 2007 | 10:05 PM
  #45
NICK YOSKIN
St. Jude Donor '08
more pics....
need to clean up the edges...
ill use 3m body panal adhesive...
Old Jun 20, 2007 | 10:55 PM
  #46
NICK YOSKIN
St. Jude Donor '08
[IMG][/IMG]
Old Jun 20, 2007 | 10:57 PM
  #47
NICK YOSKIN
St. Jude Donor '08
http://www.lytron.com/standard/exchangers.asp
here is a screen shot of the page above
[IMG][/IMG]
Old Jun 21, 2007 | 08:17 AM
  #48
chuntington101's Avatar
chuntington101
australia right? LOVE TO!
UK mate. but feel free to let me know when you are! beers will be on me!
Old Jun 21, 2007 | 08:59 AM
  #49
RoadRebel's Avatar
RoadRebel
I said talk to your "tranny builder", not Todd . There is a very BIG reason to go with a tube and fin. Continue you search and you will find enlightenment. Then when you find what you are seeking for you can decided if its a really good idea for you to run a bar and plate. Just trying to keep you from making a mistake .
Phil
Old Jun 21, 2007 | 10:15 AM
  #50
Geneus's Avatar
Geneus
Continue you search and you will find enlightenment, Grasshopper.
Fixed it for you.
Old Jun 21, 2007 | 11:18 AM
  #51
Shinobi'sZ's Avatar
Shinobi'sZ
Nice oil cooler but I probably would have placed it where PFADT is proposing with there kit. When it comes to Oil Cooler placement I like looking to those companies (DRM, LPE, Mallet, PFADT, etc) that specialize in the road racing areas as they tend to have the greatest need (given the use) for oil coolers...and thus put a lot of thought into the location.
I'm not saying that it isn't a good location for air flow...I just think there are better locations that don't effect the brake ducting.
A good example of this is AVB's locations...he has also put them to the test on the road course with the TT setup (+ iron block) and has reported back lowered oil temps after the sessions.
Old Jun 21, 2007 | 02:13 PM
  #52
NICK YOSKIN
St. Jude Donor '08
hey kevin....
yeah but to me its more important to get max. airflow and cooling then the brakes getting fresh air. if the motor is running hot i aint charging hard into the turns anyway it might be best NOT take turns to aggresively with new setup....dont wanna toss it away
how are u doing?
ride done?
Old Jun 21, 2007 | 02:21 PM
  #53
RoadRebel's Avatar
RoadRebel
Originally Posted by Geneus
Fixed it for you.
Bahahahahaha.....
Old Jun 21, 2007 | 02:25 PM
  #54
NITRO UK's Avatar
NITRO UK
Quote:
Originally Posted by chuntington101
nick you are the man!
if you are ever on this side of the world i owe you a beer!
Chris.
Yeah then take the long way home and drop in to the uk,i`ll buy all you can drink sounds like your gonna need some serious tires.
if your not in the middle of a project,then your thinking about the next one .all the best nitro uk
Old Jun 21, 2007 | 02:27 PM
  #55
NICK YOSKIN
St. Jude Donor '08
Chris.
as a matter of fact i do need tires...nitto 305 18 are bald.
Old Jun 21, 2007 | 02:33 PM
  #56
RoadRebel's Avatar
RoadRebel
Soooo,your going to run it? No enlighentment yet?
Old Jun 21, 2007 | 02:48 PM
  #57
NICK YOSKIN
St. Jude Donor '08
your not very busy?
yeah they suck to clean in the event of.......
To This Is It! Promise!
Old Jun 21, 2007 | 02:57 PM
  #58
RoadRebel's Avatar
RoadRebel
your not very busy?
You will have to throw it away everytime the trans/converter let go.
GM/Jasper/Penske and almost every engine rebuild requires a receipt for a new oil cooler for replacement gm truck engines warranty to even be considered. No matter what tanks/cleaners you use pieces will still be stuck in it and dislodge and go though the system.
Now, in your case do you really think your not going to smoke trannys/converters? Its your descision but at least now you have an enlightened one Grasshopper
Phil
Old Jun 21, 2007 | 03:05 PM
  #59
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
Nick, with those turbos we built for you, it should stall out around 162-165mph in the 1/4. I think 150+ won't be a problem.
Jose
Old Jun 21, 2007 | 03:44 PM
  #60
NICK YOSKIN
St. Jude Donor '08
Phil
no doubt there are more bucks....i got this one from my buddie who never finished his 1000 hp supra and had them laying around.
phil see that driver box? should look fimiliar to u. guess whos???
