What else should I do?
Old Jun 26, 2007 | 09:45 AM
waddisme's Avatar
waddisme
Default What else should I do?
I am changin my older P1SC set up back to the stock fan set up next week. I am also switching to 160 thermostat. While everything was apart, I thought I would pin the crank and loctite the cam bolts.
Is there anything else to do while I have everything disassembled? Would like to do all the preventive mtnce while I have help next week.
Thanks.
Old Jun 26, 2007 | 09:58 AM
kromberg's Avatar
kromberg
Since you will have the front cover off to loctite the cam bolts, I would upgrade/replace the oil pump and timing chain if you have not done so already.
Keith
