I currently have Terra Yella( old version ), but I will be switching them sometime here soon. The sewing machine affect is pretty bad. I will either us Harland Sharp or stockers. I kinda bought into the whole aftermarket rocker arm thing
Keith
I dont think they would make that big of a difference over stock but I figure Ive already replaced every stock piece on this car...I might as well replace the rockers too
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Have you been to the ls forums and seen the rocker wars?..
If you are not up to snuff on 'weight over the valve' and the problems it can cause, then you might be investing in boat anchor parts.
Not saying that they don't have some good points, just don't want you to throw your hard earned $$$ away without knowing the whole story.
St. Jude Donor '08
Pics of new yella...please....
btw: sometimes a roller will help noise, sometimes it adds a different noise, but if you get your pushrod length correct, you'll have less noise with either.
btw: total ...I make it up as I go.....
rocker will help..
chris & i've played w/different lenght pushrods.. nothing other then wallet was lighter... .75 to 1.5 turns
I've been running the Comp Cams Pro Magnum stainless rockers for over 2 years now without problems. Have them on my 91' Vette as well. Quality parts....But they did require a little hammering to clear the inside of the valve cover drip rails...
So far I'm very happy with Yella Terras... the price is right, and the valvetrain is quiet. I just can't justify spending close to the same amount to have rebuilt stockers...
