turbo size
Old Jul 10, 2007 | 07:34 PM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
Default turbo size
Hi there to all you corvette turbo Guros i neeed your help
dose any one know the exact size and spec of the
LPE turbo kit for the corvette ??????????????
Old Jul 12, 2007 | 04:51 AM
sultan 2 ZR1 KSA
OK if not specs
sizes dimentions i am planning to upgrade thim but i am not welling to cut weld or modefie my frame
dose that help
i hope it dose
Old Jul 12, 2007 | 11:24 AM
Corvette4ever's Avatar
Corvette4ever
If I remember correctly
For C5 it is garret GT28
For C6 it is garret GT30
not sure about exact specs. Also, their 1000+rwhp cars uses different turbos
Old Jul 12, 2007 | 11:51 AM
ForceFedC5's Avatar
ForceFedC5
I believe the 1000+rwhp cars require cutting of the frame to fit
Old Jul 12, 2007 | 12:44 PM
Brabus2's Avatar
Brabus2
Road and Track's article on the LPE TT C6 Commemorative states; a pair of Garrett GT28 ball-bering turbochargers that supply 10.0 psi of boost.
Old Jul 14, 2007 | 03:36 AM
sultan 2 ZR1 KSA
any recomendations on what to go for ???
Old Sep 19, 2008 | 11:26 PM
sultan 2 ZR1 KSA
hi sorry for bringing up an old story but now that i have cash to do the upgrade i realy need your help gents i am thinking of these as an upgrade , target 800WHP
http://www.atpturbo.com/Merchant2/me...egory_Code=TBO
or
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
what do think
thanks in advance
Old Sep 20, 2008 | 09:43 AM
sultan 2 ZR1 KSA
TTT
HeeeeeeeeeeeeeeeeellllllllllllllpPPPPPPP PPPPPPPPPPPPPP
Old Sep 20, 2008 | 04:14 PM
onfire's Avatar
onfire
What you need to do is send the ones you have to somebody like Mike Blouch at Blouch turbo to put the -11 or -12 chra's in your housings. This will insure they will bolt back up to your system. Google "Blouch Turbo" and give him a call....he's done it before...you'r turbos max at 44lb....mike can get them to 50-52lb which will be worth 120ish hp if you max the system.
Old Sep 20, 2008 | 04:45 PM
sultan 2 ZR1 KSA
thanks for the reply
my frind i am not USA i am in KSA so basecly i am half way accros the world so sending them and bringeng them back is a bet defecult
Old Sep 21, 2008 | 09:18 PM
sultan 2 ZR1 KSA
to the top and beyond
helps please
Old Sep 24, 2008 | 11:47 PM
hpcubed's Avatar
hpcubed
I think the GT30R turbos are ideal for the stock displacement motor.
To turbo size
