BAP Wiring
Old Jul 28, 2007 | 03:25 PM
D Lamberet's Avatar
D Lamberet
Default BAP Wiring
Just got my boost a pump today. Where do those that have them mount them. Where do you pick up the wire for the pump. And where do some of you mount the switch?
danny
Old Jul 28, 2007 | 04:51 PM
FRCTony's Avatar
FRCTony
Do yourself a big favor and get the racetronix harness.
http://www.racetronix.com/RX-C5A-FPWH-2.html
I mounted the pressure switch on the vacuum manifold, same as the bypass valve and boost gauge.
Old Jul 28, 2007 | 05:37 PM
D Lamberet's Avatar
D Lamberet
Default BAP WIRING? Harness
I need the diagram to hard wire. I would like the harness but where do you find them. It appears Racetronix distributors are in Canada. I would like to avoid ordering from Canada if possible. Takes a long time. Most of the install is done with exception of the BAP install. Any input from other forum members?
danny
Old Jul 28, 2007 | 05:48 PM
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Racetronix has a distributor list on their site. I got mine plus 60 lbs mototron injectors from Blowerworks in Jersey....very quick delivery and a pleasure to deal with.
If you do go with that harness or equivalent, the bap ends up in the rear driver's side wheel well (at least on my 03 1/2).
Search this forum, you should find pics of the install
Old Jul 28, 2007 | 08:12 PM
FRCTony's Avatar
FRCTony
Thunder Racing is probably closest to you. I don't think they have it listed on their site. Give them a call.
Old Jul 29, 2007 | 01:24 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Please see this thread:
http://forums.corvetteforum.com/show....php?t=1724064
To BAP Wiring
