A4 Tranny
Aug 4, 2007 | 05:37 PM
St. Jude Donor '05-'06-'08
A4 Tranny
What type of Fluid are you guys using with RPM Automatic Transmission! ! GM, Royal Purple etc..
Aug 5, 2007 | 10:15 AM
Anyone here running a RPM Tranny ! ! Please tell me what fluid are you using ! !
Aug 5, 2007 | 11:16 AM
I called RPM about that, they told me no synthetics. They didn't real recommend a brand, just Dextron III.
Aug 5, 2007 | 11:32 AM
Quote:
Originally Posted by
Mike04
I thought he told me GM Dextron III also ! !
Aug 5, 2007 | 09:38 PM
Really so no synthetic tranny fluid ? I'll have to remember that when I get my car back this week with the RPM A4
Aug 5, 2007 | 11:35 PM
St. Jude Donor '13
MIKE-C5
Dextron III or the newest Dextron VI.
Rodney, Which one do you reccommend?
Aug 5, 2007 | 11:36 PM
St. Jude Donor '08
MIKE-C5
CORRECT!
Aug 5, 2007 | 11:44 PM
St. Jude Donor '13
NICK YOSKIN
CORRECT!
That was before Dextron VI was developed. The Dextron VI will replace the Dextron III in everything except transfer cases as of now.
Aug 6, 2007 | 07:29 AM
I just returned from RPM the other day and they told me the same thing. I watched as they put Dextron III in my trans.
Mike04
Aug 6, 2007 | 11:56 AM
Dexron III----good thing is that even the cheap ones are the same as the expensive ones
Aug 6, 2007 | 01:31 PM
I put Royal purple in mine.
Should I change it. That's some expensive ATF to throw away.
Aug 7, 2007 | 10:27 AM
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Dex 6 here..............no issues with using the T-brake or shifting or road racing with 274 deg tranny temps
Aug 7, 2007 | 12:34 PM
ALLTHROTTLE&NOBOTTLE
One brave man. I wish you the best of luck from one on his third 4L60E tranny. Heat =
for the A4.
Aug 7, 2007 | 12:57 PM
Cruise-In V Veteran
NCM Ambassador
frank dupuy
for the A4.
Hehehe.........this is a Rossler Stage III, no problem
It took over 10K hard road race/autox/street miles and 250+ 1/4 mile passes to blow out 3RD/OD in the stage II.
Heat is bad but.................my oil was 325
on the edge but with a 6.0 iron truck block and running like I was.......I expected nothing less....now onto the oil cooler next
I don't have near the power of you FI guys.....but, I test my stuff to the limit so I know where the limit is..Hum.........that make me a test pilot
Aug 7, 2007 | 01:55 PM
What makes heat bad is that is embrittles the rubber seals. Once they get hard, they leak pressure. Then you start slipping clutches, which makes more heat. Chain Reaction starts.
Aug 7, 2007 | 02:19 PM
Cruise-In V Veteran
NCM Ambassador
RED99
Yepper....quad, o-ring, lip........but I am more worried about the hard parts than soft. It took me 2 1/2 years to break it......broke hard parts. The seals were hardnened but no leaks
Aug 8, 2007 | 03:00 PM
St. Jude Donor '13
Rodney, Dextron III or Dextron VI?
Aug 8, 2007 | 04:54 PM
gotjuice?
I called RPM and they sai Drexon III
Aug 8, 2007 | 05:22 PM
Would you guys recommend the Dex IV or III on a stock trans? I am installing a transcooler as I am doing the swap. The parts store is twice the price for IV as it is for III. Is it worth it?
Cassidy
Aug 8, 2007 | 06:12 PM
Mike04
Did RPM say why they do not reccomend synthetics ?
INTHERED
