Does anyone know if the tensioner that comes with the Paxton kit comes off another car or truck or is it made for the kit.
(The one between the balancer and the super charger.)
If it comes off another vehicle what one ?
Thanks in advance
The tensioner itself is a standard H/D NAPA part. The brackets are custom made. I cant divulge the part number though. You'll have to get that from ECS..
Thanks in advance
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The housing is a standard housing, but the spring has been replaced with a custom set up along with the direction of tension. So thats going to be hard to find at the local auto parts store.
I was looking at a different washer setup for it so i thought if it came from a particular vehicle i would look at the setup and see what washers the factory had.
WHAT!!!! You guys haven't opened up the nationwide chain of ECS autoparts??
BTW Doug, Maybe I'm thinking about a different tensioner. Do you replace the spring on the 8-rib tensioner assembly? Is it the same one you guys use with your Paxton kits?
If you need one let us know.
Aahhh, I know why Jeff, the KB/Maggie tensioner of ours which you have is different.
