pcm wiring
Old Aug 12, 2007 | 06:31 PM
slownova's Avatar
slownova
Cruising
Default pcm wiring
Im trying to get the "tach signal" and "tps or wot" and i want to tap off the pcm wiring. Anyone know pin #'s and wire colors? Vehicle is a 2001 zo6 corvette...
Old Aug 12, 2007 | 08:34 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Sending you a PM right now with the diagrams.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Aug 12, 2007 | 08:38 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
My Corvette Photos has pics of where I tapped in for both. I used the coil pack for the tach signal, and the TPS wire is blue.
Both are pictured.
Beer
Old Aug 12, 2007 | 09:12 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
oh i recently learned all about the vette's modules and how they are networked............bla!
Old Aug 12, 2007 | 09:17 PM
slownova's Avatar
slownova
Cruising
Both are pictured.
Beer
Thanks for the input, was wanting to keep as many wires inside the car as i can, i guess if i cant get it figured out i can do it your way...Thanks again
Old Aug 12, 2007 | 09:27 PM
slownova's Avatar
slownova
Cruising
Just wondering if you guys know how many connectors are on your pcm's? i have three......
Old Aug 12, 2007 | 09:31 PM
RoadRebel's Avatar
RoadRebel
411 pcms only have 2 connectors.
Also, under the dash pad left side of the steering wheel in a clutch of wire wrapped looping up to the cluster you will find a white wire for your tach signal. Also, you can grab your TPS off the floor at the gas pedal.
Phil
Old Aug 13, 2007 | 12:43 PM
slownova's Avatar
slownova
Cruising
Thanks for the help guys!!!!!!!
To pcm wiring
