D1SC Kaboom! !
Old Aug 31, 2007 | 12:34 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
Default no filter?
No filter on the intake from the charger? If you had a standard filter with that i cant see how you could have sucked something into the impeller?
Im going with bearing failure :-)
Old Aug 31, 2007 | 07:04 PM
dntalman's Avatar
dntalman
The inside shaft seized up do to inproper oiling. You must of got trash in the line somehow. It caused the metal to heat and expand until the end result.
Old Sep 2, 2007 | 10:21 AM
waddisme's Avatar
waddisme
What is Procharger say? I don't care who's it is, just sad it was someone's.
Old Sep 2, 2007 | 11:23 AM
vetterlatethannever's Avatar
vetterlatethannever
Kaboom is right though
Old Sep 2, 2007 | 12:12 PM
RED99's Avatar
RED99
If you look closely, you can see the impeller is drooped down. Which means there is no outter bearing left, or it has a broken shaft. These things turn at very high rpm, so that's why I say it's a bearing. I've seen turbos eat up impellers, but this is the first time I seen anything like this to a snail type compressor.
Old Sep 2, 2007 | 05:17 PM
American Hydrocarbon
Guest
Posts: n/a
Originally Posted by Skunkworks
check it out
Old Sep 2, 2007 | 06:24 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
It is even a dupe by the original poster
Old Sep 4, 2007 | 06:17 AM
EPP's Avatar
0EPP
Former Vendor
Originally Posted by Quick Silver Z
Sure just as I'm considering one!
Not the norm, I can assure you. Bob
