Has anyone use a Weldon pump? Are they load or problematic?
Also I was thinking about using their 14000-PWM controller. It would seem to solve the issue of over driving the fuel while cruising, yet with a Hobbs say set at 3-4 psi you would get full flow with a larger pump.
any thought or ideas on this?
I've had a Weldon pump in my Syclone since 1993. I've never used any voltage controller. I believe its the only thing on the truck that's never broken. (I honestly can't even recall how many engine and tranny combos I've been through over the years.) Two word sum up my experience with Weldons: Reliable and Loud.
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
We run Weldon Pumps 0n the Killer Bee Turbo M3 and she makes over 1100 whp and going for 1400 and the fuel supply is rock solid. They are loud, if you have seen our Killer Bee video, you can here the pump before firing the car up.
