maxing out 3bar map sensor
Old Sep 30, 2007 | 06:10 PM
morejuice's Avatar
morejuice
Cruising
Default maxing out 3bar map sensor
Using efi live with 3bar sensor. Maxing sensor out a 255kpa at 5200rpm then car goes into power reduction mode. No codes are present. wondering if computer is maxed out at 255kpa. All help and opinions are appreciated.
thanks
Old Sep 30, 2007 | 09:29 PM
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
hpt guy here, so not much help...maybe you have a 2.5 bar map sensor???
Have you ever seen 3 bar?...you could test with 30 psi air line
Old Sep 30, 2007 | 10:44 PM
onfire's Avatar
onfire
sounds like the scalar is not set correctly. what number did you set it at?
Old Sep 30, 2007 | 10:53 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
got the right PID up in your config?
310kpa is 3 bar
Old Sep 30, 2007 | 11:42 PM
morejuice's Avatar
morejuice
Cruising
310kpa is 3 bar
At 5200rpm the pid is reading 255kpa then 300rpm later it goes into pr mode. Trying to figure out if the pcm is maxed out at 255kpa or if its the sensor. It has never read higher than 255kpa but i can watch the boost gauge and it continues to increase. So if the 3bar is good to 310kpa do i need to change something in the pcm.
Old Sep 30, 2007 | 11:44 PM
NICK YOSKIN
St. Jude Donor '08
yes is in your scanner section...you need to choose 3 bar
Old Sep 30, 2007 | 11:55 PM
morejuice's Avatar
morejuice
Cruising
I am using roadrunner and it is set on 3bar. I still need to change it in the scanner?
Old Oct 1, 2007 | 09:07 AM
No Juice's Avatar
No Juice
Old Oct 1, 2007 | 09:13 AM
NICK YOSKIN
St. Jude Donor '08
i am sorry, not familiar w/that set up but its gotta read 3 bar no matter what scanner it is. gotta fart around w/it and see.
Old Oct 1, 2007 | 11:14 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
How much boost did you say you were running?
Old Oct 1, 2007 | 07:50 PM
morejuice's Avatar
morejuice
Cruising
Its maxing out my boost gauge at 30psi.
Old Oct 1, 2007 | 08:19 PM
Hool97's Avatar
Hool97
Need more info about set up? what engine, what hp. You can check the output of the 3 bar sensor relatively easily with a volt meter. 5v system. Does the voltage increase beyond the software reading 255kpa or does it hold at say 4 volt or has it already hit 5 volts and the MAP is really a 2.5 bar map.(strange because if it were a 2.5 bar MAP you would just read 310kpa when you really were at 255kpa).
That should narrow it down to the scanner or ECU.
Old Oct 2, 2007 | 01:28 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
FWIW even a 3bar won't go past 30. At 255kpa (around 22.5 psi) though it sounds like you are setup for 2.5bar.
Old Oct 2, 2007 | 04:58 PM
stevieturbo's Avatar
stevieturbo
Any part numbers on the map sensor ??
As already mentioned, a 3 bar sensor is typically 310Kpa.
Old Oct 2, 2007 | 06:09 PM
morejuice's Avatar
morejuice
Cruising
Part number is 12223861 and im pretty sure its an acdelco sensor.
As far as more info on my set up: 98 vette 408 9:1, L92 heads by TPIS, L76 intake,cam 238 248 605 615 on a 115, kooks 17/8-2 step headers, magnafuel fuel system,ram street twin, F2 procharger non intercooled on E-85. The reason the boost is so high is because of the restrictive intake and the small cam.We're in the 4 digits at about 6000rpm, but it keeps going into pr mode.
Old Oct 2, 2007 | 09:29 PM
RJW's Avatar
RJW
St. Jude Donor '08
That number is a 3 bar sensor....same as my MSD 3 bar fwiw
not familiar with efi live, but I would check voltage vs boost...could just need a custom pid, but first you need to know that the map is or is not putting out the correct voltage.
Old Oct 6, 2007 | 11:38 AM
LEANDRO's Avatar
LEANDRO
ttt for morejuice
To maxing out 3bar map sensor
Old Oct 6, 2007 | 11:49 AM
Yellow03Z06's Avatar
Yellow03Z06
I ran into the same thing on my Starion. I switched to a 3.5 bar map and was able to boost to 35 psi. They also sell 5 bar map sensors, but the resolution is not so good. They are only for race cars. I got mine from SSI technologies. You can get one from AEM also. Good luck.
Old Oct 6, 2007 | 07:38 PM
Warp Factor's Avatar
Warp Factor
Its maxing out my boost gauge at 30psi............non intercooled on E-85
Old Oct 7, 2007 | 12:14 AM
blu00rdstr's Avatar
blu00rdstr
I took the stock 1bar MAP sensor from the back of my LS1 manifold and was about to plug it into the front of my L76 manifold. I noticed the seal was wasn't tight. Is this common?
Also, is the 3bar MAP sensor a direct fit to the L76, or does it use a vacum hose connection?
