New Ecs Bracket Installed!!!!!!!!!!!
Old Oct 29, 2007 | 10:30 PM
  #41
LB's Avatar
LB
As you can see the core you are using 18" (in the middle) flows about 20-25% less than the larger 25" long core we use. The larger core is rated to flow is 1500-1600 CFM. If you estimate your core only flows 1200 CFM, than you have one serious restriction on that 2000 CFM head unit. Switch the core and you will be able to make more power with less boost.
Old Oct 29, 2007 | 10:54 PM
  #42
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Originally Posted by easyvette
How do you go about that without sending the unit back to procharger? My understanding is procharger puts a new back half on when reclocking the oil slinger in the blower? I am not sure if my comment is a fact?
The blower is made with 3 machined spots where the oil slinger goes-all that happens is you pop it of 1 and drop it in the other. You should send it back to Procharger as you will need a new dipstick as well-I think the cost is like $125. BUT if your mechanically inclined it can be done at home-you'll just need to order a new dipstick. I may have some pics of the unit apart-pm me if you need them.
Old Oct 30, 2007 | 09:06 AM
  #43
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by eb02z06
Well I dropped in my new CDN PERFlongblock this weekend and started mounting my NEW ECS PROCHARGER BRACKETS!!!!!!They mounted up with ease!!!!!! Belt installation was a breeze, and my god-tightening the belt was so easy-Doug&Chris hit this right out of the park with the Novi and now the Procharger bracket!!!!!One word of caution-you cannot use a pulley smaller than 3.8"-so this bracket is for those that want to make BOOST!!!!!!!!!!If I get a chance I'll dyno the car, if not I'll be at the track for sure!!!!!!
A quick thing that needs to be clarified Arun, the brackets CAN use up to a 4.5" or maybe 4.75" pulley. The only difference is that a pulley larger than 3.8" has to be installed before the head unit is installed (like all other ATI brackets that I know of) and a 3.8" or smaller can be swapped with the head unit mounted.
Old Oct 30, 2007 | 04:49 PM
  #44
Doczo6's Avatar
Doczo6
WOW nice, you can swap pullies without removing the blower
