New Ecs Bracket Installed!!!!!!!!!!!
Old Oct 28, 2007 | 10:03 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Default New Ecs Bracket Installed!!!!!!!!!!!
Well I dropped in my new CDN PERFlongblock this weekend and started mounting my NEW ECS PROCHARGER BRACKETS!!!!!!They mounted up with ease!!!!!! Belt installation was a breeze, and my god-tightening the belt was so easy-Doug&Chris hit this right out of the park with the Novi and now the Procharger bracket!!!!!One word of caution-you cannot use a pulley smaller than 3.8"-so this bracket is for those that want to make BOOST!!!!!!!!!!If I get a chance I'll dyno the car, if not I'll be at the track for sure!!!!!!
Old Oct 28, 2007 | 10:15 PM
Cliff99C5hardtop's Avatar
Cliff99C5hardtop
I got mine Saturday but I didn't install mine yet, I took my D1 off to send to ATI to have them go over it(seals etc). Just precautionary since it's off. The bracket almost looks too simple compared to the older style. Looks great!!! Can't wait til the D1 comes back now to put it on.
Did you happen to use the same belt as before or do you need another size.....even Chris (ECS) wasn't sure if it would be the same.
Old Oct 28, 2007 | 10:16 PM
LB's Avatar
LB
Those looks like some shiney new heads to. You holding out ?
Old Oct 28, 2007 | 10:50 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Just another set of budget Patriots bro-72cc this time with some good valves-nothing fancy here!
Old Oct 28, 2007 | 10:52 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
3.55 pulley with a 8" crank requires a 89.7"
Old Oct 28, 2007 | 10:54 PM
mitymikec's Avatar
mitymikec
Let me know when u fire that monster up..The shiney parts look good.
Old Oct 29, 2007 | 01:08 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
In your first post you said that the smallest pulley is 3.8" is that correct or is that the LARGEST pulley you can use with this bracket?
Old Oct 29, 2007 | 01:48 AM
use2bl8's Avatar
use2bl8
Nice! Looking forward to some track times.
Old Oct 29, 2007 | 06:32 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Sorry, that is what I meant!
Old Oct 29, 2007 | 09:18 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I should be ordering mine very shortly
Old Oct 29, 2007 | 09:33 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Aurn that looks great and can not wait to see the results at the track
Old Oct 29, 2007 | 09:35 AM
black98c5's Avatar
black98c5
Arun, are you staying with stock cubes and same CR as your previous motor? Congrats and can't wait to see some results!
Old Oct 29, 2007 | 10:22 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Bro-this is a CDN PERF 402. I either needed to get a bigger stall or go bigger cubes-so I went for the bigger cubes cause the cost of getting a new stall and getting it installed-it was cheaper for me to sell my 347 and upsize it! I kept the CR the same-10.1-I feel it is the perfect ratio for making big power and torque with a centri! Plus this allows me to try those new crazy L92 heads as well!!!!
I can't tell you how pumped up I am about this new bracket-and I have few more ideas for next year that I'll be going over with ECS as well, like a cog setup. I know there already is a setup out there but I know ECS can make it better!
Old Oct 29, 2007 | 10:35 AM
black98c5's Avatar
black98c5
Wow! You went all out this time for sure.
Old Oct 29, 2007 | 10:48 AM
LB's Avatar
LB
402 I knew you were holding out
Does the patriot heads have a tall deck design like AFR and ETP ? I figure 20psi give or take might be pushing the limit of a standard deck head.
PS. what happened to your LS2 intake ?
Old Oct 29, 2007 | 10:54 AM
SLED28's Avatar
SLED28
St. Jude Donor "08
Some people can tune around the thinner decks
Arun, time to get this badboy out and set the Canadian record, supercharger record, all on 26's! The year 2007 is a long way from over! I can't wait buddy!!
Old Oct 29, 2007 | 10:56 AM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
[QUOTE=eb02z06;1562503516]Well I dropped in my new CDN PERFlongblock this weekend and started mounting my NEW ECS PROCHARGER BRACKETS!!!!!!They mounted up with ease!!!!!! Belt installation was a breeze, and my god-tightening the belt was so easy-Doug&Chris hit this right out of the park with the Novi and now the Procharger bracket!!!!!One word of caution-you cannot use a pulley smaller than 3.8"-so this bracket is for those that want to make BOOST!!!!!!!!!!If I get a chance I'll dyno the car, if not I'll be at the track for sure!!!!!!
Another motor Arun what are your shooting for now 1200rwhp
To New Ecs Bracket Installed!!!!!!!!!!!
Old Oct 29, 2007 | 11:00 AM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Hey bro-I told you I was installing a new motor on friday-you didn't catch that did you? Deck isn't an issue-Harlan and alot of the boys have run well over 20 psi with stock castings. From my experience in the Mustangs this was not an issue either-remember I ran 9.40's with a Novi and a lttle 302 back in 97-no intercooler or meth either. As long as the motor doesn't detonate-it will be fine-just have to have the right octane of fuel when running meth-you can't run C16 and meth together.
Old Oct 29, 2007 | 11:02 AM
LB's Avatar
LB
I always say beter safe than sorry. I understand that detonation is usually the culprite when it comes to lifting heads, but I am sure you can push past the gasket with enough boost. Anyway, im not hating, just my two cents. Good luck boys !
tlaselva's Avatar
tlaselva
Cogged? Now your talking!
