Using my car as an example, I currently am pushing 8 lbs of boost on the stock 8lb wastegate springs in the APS TT kit.
I'm in the process of purchasing Lowboost's Patriot 317's and GT2-3 cam. I'm not planning on putting this on to the stock shortblock, but a question sprang to mind.....
As you increase the motor's VE, the boost should see a relative drop. But, being that the only thing controlling the boost is the wastegate springs, if I was to install the stuff on the stock shortblock, would it still come up to the 8lbs boost because that's what the wastegate springs are looking/waiting for? I really don't know the answer to this one, which is why I'm asking.
If I understand your quesitons correctly the answer is YES. it will still make 8psi whether you are running your current setup or the new heads/cam. as long as thats what the spring pressure is and assuming you don't have problems getting rid of the excess gasses.
the difference with the better flowing heads/cam, as you pointed out already, is that your VE will increase so you will flow more air threw the motor w/less restriction. Thats all boost is after all, a restriction. If you can move the same amount of air with less pressure you are moving in the right direction.
Thanks! I just wasn't sure if I was thinking straight on that one or not. Of course, leaving it at 8lbs might not be the smartest idea because even though the boost is still only at 8 PSI, the cylinder pressures are still going to be increased via the extra airflow.
Turbos don't change, because the boost is control by spring pressure.
Blower cars change, because there boost in controlled by pully size.
And the GT2-3 cam is a little cam. It is comaprable to a stock Z06 (LS6) cam.
I realize that. But coupled with come Patriot CNC'd 317's it opens things up quite nicely. Plus, I'm sure there's some pretty noticeable differences in a stock LS6 cam when compared to a GT2-3 if you dig deeper into the specs past the standard duration @ .050, lift, and LSA.
As far as HP goes, there isn't much difference between the two cams. I have a GT2-3 cam I will be pulling out after Christmas if you want to buy one with about 2500 miles on it.
I also ran a GT2-3 cam and worked over stock heads with my TT kit on a stock lower end. You can definitely make good power, the only issue is potential longevity.
To answer your question you'll still make 8 psi but generate more hp.
Since the stock (weak) lowerend is still being used I wouldn't bother with the H/C and just turn the boost up to 12lbs instead. Either setup is going to stress the lower end more.I would save the $$ and do a forged motor in the future instead.
That's already the plan. I bought the heads/cam setup to sit on while I locate a stock block and crank and get some forged rods/pistons and do a budget short block. I posed the question here because I really wasn't sure if those wastegate springs would give 8 lbs boost on any setup or not. Newb to turbo's still.
Sean, you will have some fun getting those twins out of there, I worked my azz off on that car for weeks to get things to fit
seperate the turbo housings, not in the APS tech data for rem'l or install, but I see no other way
Hope your having fun with the car, that was quite a project, I would've have really like to see how the tuned result was
Thanks for the tip! I was just recently pondering what it's going to take to get that motor swap done in the garage with the turbo's hiding in there pretty good.
I'm having a blast with the car. The smoothness of the powerband coupled with how quiet it is overall is just awesome. It's so beautifully deceptive. I think if you'd have gotten to run in it fully tuned you'd probably have one on your FRC by now!
