Engine Size vs Powerband vs Power adder
[/QUOTE]Lets start off with a 346 and at least 150 shot, heads cam or stock does not matter.
2. Stroked or bored motor at least 370ci or more with minimum of 150 shot.
3. Stock cubes forged or not with a maggie no spray
4. Stock cubes forged or not with a maggie and spray
5. Stroked or bored with a maggie(112 or 122) no spray
6. Stroked or bored with a maggie(112 or 122) and spray
7. Same as 3-4-5-6 but with a centrifical blower regardless of brand just list what it is
8. Stock cubes with TT.(please identify kit)
9. Stock cubes with single turbo (please list turbo size)
10. Stroked or bored with TT
11 Stroked or bored with single turbo
12. Fully built N/A stock displacement.
13 Fully built NA stroker motor larger the better.
The point of this thread is not to put anyones kits or combo down but to see were each of these combos start to make power and were it ends. I am really curious to see were most of the power curves peak and how high or low in the rpms all this occurs. I really want to see how many setups actually are making power in the 6000+ range along with how fast the torque drops in the upper rpms.
Heres mine fully built 364 LS2 APS TT 2005 GTO with GT3071 T28 flanged at 15psi clutch started to slip a little on the top end.
Les
Les
MTO What is your combo graph looks very nice, the one thing that is already becoming apparent so far in the few examples is it seems like 6200 rpms is were power seems to fall. That is why I posted this thread because it seems like most cars I see with the exception of big Centrificals dont pull much past 6200 to 6500rpms.
Les
Here is a graph with my current setup... a 60-1 turbo at 9psi tuned in 107F ambient, catless full 3" with Corsa Sport
5.3's die off up top because the stock cam is horrible for forced induction. An 02+ LS6 cam only upgrade can literally add 100rwhp... really allowing the 5.3 to breathe up top.
On the horizon is a TC66 with an F1 wheel, 4L80E/Vig3200...
Bill
Les
1998 LS1 - 346 CID - A4 - 342 Gears - YANK 3200 - TFS Heads 215's - 224/228 581 588 114 - P1SC 7.6 PSI B@@ST - 10.9 Comp - Methanol ALKY Control Kit - LS6 Manifold - Ported TB - KOOKS Headers etc. more in the sig below! all on 86,000 miles and a stock bottom end
All equals - 591 RWHP and 496 RWTQ
Thanks,Matt
Thanks,Matt
Les
