Meth tanks
Old Jan 23, 2008 | 07:08 AM
Jeffyvette's Avatar
Jeffyvette
Default Meth tanks
My mechanic plumbed this system up. I have a little over 3 gals of capacity. It all fits insde the fender area. I am using the car to run in Open Road Races. I will averaging 170mph with speeds over 200 for 90-130 miles. So this should fit the bill.
http://www.boomspeed.com/jeffyvette/methtank2.jpg
Jeffy
sorry I did not realize the pic waqs so big, I am not sure how to resize. For better pic see posting below that has been resized
Old Jan 23, 2008 | 06:11 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Not bad! But do you have a smaller picture in order to appreciate the whole scope of it?
Thanks,Matt
Old Jan 23, 2008 | 09:32 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks like one sweet setup and you will not run out of meth with that much on board when you do those runs
Old Jan 23, 2008 | 09:34 PM
AMRAAM's Avatar
AMRAAM
Here, try this pic. It's a little easier to see the overall pic
Old Jan 23, 2008 | 09:45 PM
Blue Lightening's Avatar
Blue Lightening
Have a good fire suppression system in there in case something happens?
I only have it a gallon in the windshield reservoir. If it catches fire in an accident there probably isn't much difference between three gallons than one. But wondering what your thoughts are.
I think there is less risk with the external tanks than the rear mounted ones in the cabin.
Old Jan 24, 2008 | 09:28 AM
Jeffyvette's Avatar
Jeffyvette
Default thanks
Thank you for resizing. I won't be running pure meth but a 50/50 water mix. So I don't think it will still be a fire hazard. lso the sactioning board for Open Road Racing would not allow a tank in the car.
Old Jan 24, 2008 | 10:59 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Are you going NA or FI Jeff? I found that I barely used my meth at the SSC because I didnt need anyware near the amount of power I had on tap to go that fast.
Looks good.
Old Jan 24, 2008 | 07:56 PM
NemesisC5's Avatar
NemesisC5
Old Jan 25, 2008 | 01:14 AM
Jeffyvette's Avatar
Jeffyvette
Default Power adder
Twin turbos, oh well if I don't use as much as I think then I won't have to fill up as often. Also I will be averaging 160 or 170 and shooting for 200+ through the traps.
Doug also I checked the rules for SSCC and still no chutes, Idiots.
Jeffy'
Old Jan 25, 2008 | 07:41 AM
Tomulrich's Avatar
Tomulrich
Here is mine SS...holds 1 3/4 gal of meth.
Old Jan 25, 2008 | 09:09 AM
coolnick's Avatar
coolnick
For cheap plastic reservoirs and vented lids check out http://fluids.flambeau.com/
I had a 5 gal res with a vented cap in my DSM and I paid around $30 for the setup. I didn't want to refill the res all the time.
Old Jan 26, 2008 | 08:47 PM
NemesisC5's Avatar
NemesisC5
Nice Setup
Thanks for the link...I would like to re-locate my battery to the rear compartment & use one of these tanks for my meth with a low level indicator light...has anyone done this & if so any pictures?
To Meth tanks
