help will this work?
Old Jan 27, 2008 | 05:45 PM
9secz06's Avatar
9secz06
Default help will this work?
I have an 02 z06 with stock bottom end, tsp stage 2.5 heads, a lg g5x3camshaft. I just bought a rear mount turbo kit w/meth set-up. Can I run 5-6psi safely?The car will have racetronix pump w/60lb injectors and unknown tuning software.
Old Jan 28, 2008 | 07:37 AM
9secz06's Avatar
9secz06
Default help
Anyone?
Old Jan 28, 2008 | 08:18 AM
MYLS6's Avatar
MYLS6
Im no expert but I have read alot on here and I believe the psi you are pushing will be ok..shouldnt be an issue
Old Jan 28, 2008 | 10:05 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You will be absoloutly fine with the 5-6 PSI you actually could go 8-10PSI safely especially since you have the metahnol kit!
You should easily be able to be in the mid 500's to 600 RWHP with your new set-up!
You will need to have it professionaly tuned on a dyno though, you will not just be able to pop the system on and go! there are certain tables that need to be set and delt with - Ex: Your 60lb injectors need to have an injector calibration done even before you start the vehicle
Find a tuner in your area and have them do the dyno tune for max HP and TQ!
Thanks,Matt
Old Jan 28, 2008 | 02:34 PM
9secz06's Avatar
9secz06
Default help
Thanks guys. I forgot to mention it's on a 112 not a 114 which I think will hurt me.Any body ran this cam with boost. I used the search and I still can't find out a yes run it answer or no it will hurt you answer.
Old Jan 31, 2008 | 03:13 PM
9secz06's Avatar
9secz06
o.k. I tried the search function again and scored.
Old Jan 31, 2008 | 09:55 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
You can do it but I wouldn't garrenty an early spool time with that setup.
To help will this work?
