which blower????
Old Feb 7, 2008 | 08:39 PM
  #41
Dave concrete's Avatar
Dave concrete
ECS NOVI a perfect recipe for quiet,quality,insane power I drive my stock 04Z 581rwhp 488rwtq and it drives like it was stock until you lay into it then holy crap still gives me the shakes.
Old Feb 8, 2008 | 08:55 AM
  #42
blwnc5's Avatar
blwnc5
Originally Posted by snitz
Thanks. I've had the pleasure to work with Doug on getting SC advice(& the ECS components listed above) and Bob at EPP who did the engine/drive train work for my street/track car and is working with me on my track only car project this winter. Both those guys have a ton of experience and I would recommend you speak with them to help pin down your choice. They not only have PHD's in building fast cars but are great guys. Good luck which ever choice you make.
That is one beautifull car, Good job.
Old Feb 8, 2008 | 11:28 AM
  #43
Drewstein's Avatar
Drewstein
I put down 641rwhp with the stock heads, bottom end, and 91 octane with a D1.
Where are the other blowers in relation to that?
Now I have a forged 402 with over 800rwhp on 91 and the same D1. I say D1. Only recently have I considered an F1 for my bigger motor.
Old Feb 9, 2008 | 01:54 PM
  #44
427fIc5z06's Avatar
427fIc5z06
Right on!
Old Feb 11, 2008 | 06:22 AM
  #45
EPP's Avatar
0EPP
Former Vendor
http://www.exoticperformanceplus.com...html?item=1136
The kit that I have put together that is shown in the link here can grow with the car. The D-1SC is what we have in Snitz's 04 that is making 740 rwhp on our Mustang Chassis Dyno at 16 psi. The D-1SC can be run at 7-8 psi or pullied to make 16 psi. I sell this kit with 60 pound fuel injectors which work great on stock engines up through (when upgraded fuel system is used) 750 rwhp. Bob
Old Feb 11, 2008 | 09:11 PM
  #46
robert miller's Avatar
robert miller
Default Ttt
TTIX KIT HAVE ALOT OF FUN....
Old Feb 12, 2008 | 12:40 AM
  #47
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
I have two paxtons. Had STS, your results might vary
Old Feb 12, 2008 | 08:37 AM
  #48
snitz's Avatar
snitz
Bob did a great job!
Old Feb 14, 2008 | 08:02 AM
  #49
BobJ's Avatar
BobJ
I like Snitz' post. Any tuner is going to ask you this; "What is your goal?" My "goal" was I don't want to blow up my motor, I want 500 RWHP on a low boost setting (8lbs +/-), I want lots of low end torque on my stock 346. I live in Phoenix so an intercooler was essential.
My goals were not (and still aren't) to turn up the boost, forge, and make 700 RWHP. I wanted a fast street car that would send me from 0-70 as fast as possible without breaking stuff. That's what I got....with my Kenne Bell!
VERY happy with the end result, no issues (belt or otherwise) in 6,000 miles 12-months. ECS and A&A are PROVEN centri applications, you can't go wrong with either if the centri is the best fit for your goals.
It's a very tough decision, I was a hair from sending my car to A&A, had a talk with ECS but I'm happy with my decision. Good luck!!
Old Feb 14, 2008 | 01:45 PM
  #50
Varmit's Avatar
Varmit
St. Jude Donor '08
I will try and add my .02 worth. I would suggest the A&A Vortech set up. However I would go with the T trim with a larger pulley. If you go with the S trim, you will eventually want want to go to something larger down the road. You can keep the boost down to an acceptable level and change pulleys later on if you want. You can only go so far with the S trim.
Now to the type of unit. I choose the centrifugal. But the type will be a matter of what YOU want. I wanted a little forward motion before the monsters came to play and all hell breaks loose. You may want it all on the bottom end. A matter of personal choice. So good luck on your decision. There are a numbe of good FI shops and tuners here. I can only speak of the one that I have use, A&A. They have always been great to me. I've had no problems with the setup, and Andy has always been first class in everything I have come to him with.
Old Feb 14, 2008 | 04:13 PM
  #51
speeddemon2007's Avatar
speeddemon2007
Thanks guys for ur time and opions! Its greatly appreciated! You all have awsome set ups! Will see with time which one I go for! I'm thinking about the magna charger! im not looking for crazy hp, so after reading a lil about this kit, it might just be the one!
Thanks again
