I have read so many threads about traction issues and trying to find the right street tire...
Do you guys still have your front sway bar connected?
Traction is about weight transfer, (and some right pedal control)... I am able to drive my tti-x at 18# on the street on 315x40x18 BFG drag radials (@25-28#) and I do not have traction issues.
I didnt have much luck with pilot sports on the street.. that is why I went with a BFG Drag radial for daily driving.. we dont get much rain in Phoenix... so the bald center patch isnt a factor
You sir have a boost leak!! Take the car back to the dyno. I am having a hard time believing even minus the front sway bar you can launch your car hard on 18 inch drag radials using 18lbs. If you said 16 inch drag radials I could believe, but come on. The TTi X turbos hit too hard not to break loose 18 inch drag radials. Dont you have a auto with a good size stall?
Nope.. no boost leak, my lil 347 is putting out over 900 rwhp... I never said that I leave hard with 18# either.. I have a manual boost controller and RPM Level 5 6 speed.
Anyway... I was refering to the street driving issue that everyone is complaining about not a track issue..I use ET Streets for the track and trap an average of 147 (best of 149) in the 1/4....
Must be nice!!!! Let's get a video of this said launch sir... I need some hope... As of now even rolling into it I can spin the tires from a 40mph roll. I run 335 nittos..
Ran a 10.78 on the same BFG Drag radials I drive on the street... went to the track... air down to 15# and dropped the hammer... 10.78@134. DA was around 1800 that night ...
It bogged a little on the line since this was the first pass (and last) of the night.....
we dynoed 725 at 13#.. This is with alky and racefuel...
Since then i added the ECS fuel system, and a second alky nozzle and upped the boost....
Good run!! Very hard to see the launch actually... Just by listening to it it sounds like you were spinning some via hearing the motor rev so fast when you took off. I could also hear the boost leak. Just kidding.... I guess I am going to take off the sway and see what happens..
Its not a bear to install... but trying to launch with the right boost + right tire pressure + get the track conditions right is what I am refering to....
Yes...I have a 2 step as well. I just don't like it. At the time the only one I could find was incorporated into the MSD LS box. Unfortunately with this box you have to input your timing map in the box and use a laptop to adjust the rpm limits. From what I understand the Synergy uses dip switches (or something like that) to adjust RPM. I just may get one of those.
Its actually a screw to adjust what RPM to studder at. Very easy to adjust...
Mine's been gone for about a year. Didnt help on the street (335/30/18 Pilot Sports), but I am pulling 1.54 60' at the track (on an ET Street).
How is your handling on the street, i dont track the car, but i have a STS system putting down about 600whp. does the car still feel the same driving around town without the front swaybar?
