Drag suspension Setup
Old Mar 8, 2008 | 08:56 AM
corvetteracer22's Avatar
corvetteracer22
Default Drag suspension Setup
What is everyone doing for a drag suspension setup? Coilovers, qa1 adjustable shocks, change spring rate etc.
Let me know
Matthew
Old Mar 8, 2008 | 09:45 AM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
nothing, mine is just as it came from the dealer!
Old Mar 8, 2008 | 12:07 PM
easyvette's Avatar
easyvette
You may have better luck in the drag racing section of the forum... Good Luck to you. I`m just on stock suspension...
Old Mar 8, 2008 | 12:27 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
i would think if you were looking for a drag only car then 90 10 shocks would be the way to go, me i run coil overs and while my car isn't perfect for the drag strips it does hold it's own and can also rip it up on the turns
Old Mar 8, 2008 | 01:34 PM
FreddyG's Avatar
FreddyG
On some street/drag cars, loosening up or taking off the front sway bar seems to help transfer weight.
Quite a few Guys use the QA-1's because it's a click away from street to track setting.
I'd recommend that you get a CCW drag pack too with the amount of power that you're putting out because if you hook up with drag radials, you're going to break parts.
Good Luck Matthew!
Old Mar 8, 2008 | 01:43 PM
4DRUSH's Avatar
4DRUSH
Stock suspension here also (Bilstein shocks)
Old Mar 8, 2008 | 02:56 PM
STEALTH 99 C5's Avatar
STEALTH 99 C5
Adjustable Q-A1's in front , Bilsteins in the rear , best 60ft 1.36 .
Old Mar 8, 2008 | 04:15 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I run no front sway bar with CCW slicks and skinnies. Some of the guy's are using less expensive 90/10 Lakewood drag shocks with very good results. Here is the link
http://forums.corvetteforum.com/show....php?t=1688142
I am not using them YET, but will in the future.
If you decide to go with them, they are available from forum vendor HorsePower Sales 954 984-8040
Old Mar 8, 2008 | 04:23 PM
racerrob333's Avatar
racerrob333
i use a 90 10 shock(a mustang shock) on the front and qa1 on the back and no front sway bar
Old Mar 9, 2008 | 12:13 PM
corvetteracer22
thanks guys for the responses on your setups. all the info I can get helps
Old Mar 9, 2008 | 03:17 PM
396375's Avatar
396375
St. Jude Donor '08-'09
:[/QUOTE]
Good Luck Matthew! [/QUOTE]
Can you explain?I don't understand the difference between hooking with the CCW drag pack or drag radials as far as breaking parts.
Thanks.
Old Mar 9, 2008 | 03:52 PM
ChopperLoco's Avatar
ChopperLoco
Thanks.[/QUOTE]
Typically,the guys who run a drag pack run a bias 16" rear tire that has more of a wrinkle type sidewall,and is much less shocking to the drive line when they hook than a drag radial,especially when you run a 17 or 18" drag radial.(also the bias tires are avail.26,27&28" for even more sidewall) Dominic
Old Mar 9, 2008 | 05:00 PM
98vettedave's Avatar
98vettedave
Bilsteins front and QA1's rear. Wheel hop is no longer a issue.
To Drag suspension Setup
