Forged 346 + YSI
Old Mar 10, 2008 | 04:38 PM
rplaster's Avatar
rplaster
Default Forged 346 + YSI
Here is what i'm running
A&A Vortech Kit YSI blower
A&A 8 rib pulley
A&A Fuel system
Forged 346 By Intune 9:1 compression.
Patriot Stage 2 heads
Cam specs 224/228 581/588 on a 114
1 3/4 Stainless Works headers
Well we were guessing on pulley size and went way to big. Only making 10#'s @ 6600rpm. Made 540 on a Mustang dyno not even getting into this blowers efficiency range. Smaller pulley on the way. Thanks to Andy @A&A his kits are well made and easy to install. His fuel system was very easy to install. Also thanks to Intune Motorsports for biulding the motor and my friends for all thier help. Big thanks to JAXX on this forum for always helping with my projects. As soon as i get the smaller pulley i'll post the results.
Old Mar 10, 2008 | 05:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks like you will have a really stout setup when you pulley down and get more boost
Old Mar 10, 2008 | 06:16 PM
MotleyDrew's Avatar
MotleyDrew
SOmeone finally joined me and Stevie with a YSi Welcome aboard
I assume you have an 8inch crank pulley but what pulley were you running for the 10lbs and what size is on the way?
Old Mar 10, 2008 | 06:22 PM
Mike04's Avatar
Mike04
I'm sure the YSI has a lot left in it. I'll be looking forward to the updates. I've been thinking of going to a YSI someday.
Old Mar 10, 2008 | 06:31 PM
rplaster's Avatar
rplaster
One thing that surprised me is how quite this blower is. I had a P1SC on another vette that i had and it was very loud at idle.
Old Mar 10, 2008 | 06:35 PM
rplaster's Avatar
rplaster
Talked to Andy today and he sent me a 3.15 pulley. I don't know what size the bigger pulley is there is no writing on it but i think it's around 3.5??
Old Mar 10, 2008 | 06:37 PM
MotleyDrew's Avatar
MotleyDrew
Cool ! I am just trying to compare it to my setup a bit for reference as I see 11lbs with an 8 inch crank and a 3.15 but on a 403ci. I have a 3.0 sitting in the garage that I will try after my first tuning phase. Goodluck and keep us posted !
I know Andy was running a 2.85 at one time but I think he said it was slippin a bit on the 427 he used to have.
Old Mar 10, 2008 | 06:41 PM
rplaster's Avatar
rplaster
Sounds like the 3.15 might put me where i need to be. I would like to see 14 or 15#'s
Old Mar 10, 2008 | 07:23 PM
MotleyDrew's Avatar
MotleyDrew
I think it will be good for around 14 - 15 on a 347 as well
Old Mar 10, 2008 | 07:40 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Ohhhhh! Yeah that is sweet!
You will love the numbers and the power when you are done getting the smaller pulley!
What size is on there now?
I have a 3.2" on my P1SC and am putting on a better bracket, A&A P1 Bracket, to pick up the belt slippage I am getting!
It would only do 10 PSI and it should be at 12 PSI - the new bracket will be here friday
We are shooting for 630 - 650 RWHP from the current break in number on the new forged motor of 607 RWHP!
What is your RWHP goal too?
Thanks,Matt
Old Mar 10, 2008 | 09:13 PM
rplaster's Avatar
rplaster
Thanks,Matt
I'm shooting for over 600 on the Mustang Dyno. Should be close to 700 on a Dynojet. I'm trying to stay with pump gas no methanol.
Old Mar 11, 2008 | 10:45 AM
robert miller's Avatar
robert miller
IT WOULD BE GOOD AT THESE # BUT WOULD LOOK AT THE METHANOL..
Old Mar 11, 2008 | 11:30 AM
JAXX's Avatar
JAXX
Good to see it up and running!
Anytime on the help, I think you have more time in my car than on yours.....LOL I should be telling you thanks again!
600 will be no problem with the smaller pully!
JAXX
Old Mar 13, 2008 | 05:37 PM
rplaster's Avatar
rplaster
Got the pulley today and man what a size diference. Might get it on the dyno this weekend. I'll post results.
Old Mar 13, 2008 | 07:02 PM
TRIZ's Avatar
TRIZ
With the 3.15,
If you get up to 6500 rpm you'll turn the Ysi to over 66,000 rpm. Assuming 5% belt slip.
What's the max recommended rpm?
I heard about guys who turn the Ysi to 80,000. Apparently the thing is almost bulletproof.
Old Mar 13, 2008 | 07:57 PM
vetterlatethannever's Avatar
vetterlatethannever
My P1 is very loud at idle, although I think some has to do with the bearings going out
Old Mar 13, 2008 | 08:56 PM
stevieturbo's Avatar
stevieturbo
Originally Posted by TRIZ
With the 3.15,
8.0/3.15 would only spin it to 57k
They use a 3.45 step up.
To Forged 346 + YSI
Old Mar 13, 2008 | 11:04 PM
TRIZ's Avatar
TRIZ
Vortech V-7 YSi-Trim Supercharger
"Large blower" performance in a smaller package that fits most existing Vortech bracketry
Fits engines up to 1200 horsepower
Maximum airflow: 1,600 CFM *
Maximum boost pressure: 30 PSI *
4.25:1 internal step-up ratio
Maximum impeller speed: 65,000 RPM
Adiabatic efficiency: 78% **
Available with straight or curved discharge in clockwise rotation only
Part numbers below do not include drive pulley
9.162" Wide, 10.490" Tall, 6.126" Deep (not including input shaft)
Is this the wrong blower?
If so, sorry my bad.
Old Mar 14, 2008 | 03:10 AM
stevieturbo
The V27 has the 4.25 step up...
Otherwise at 8.5" crank, and 3.0" blower, and 7000rpm max...Im spinning my V7 a tad too hard
Old Mar 14, 2008 | 06:47 AM
racerrob333's Avatar
racerrob333
good numbers Tony not going to know what to do with all these fast vettes
