New combo
Old Mar 26, 2008 | 08:31 PM
rplaster's Avatar
rplaster
That cam sounds wicked.
Old Mar 26, 2008 | 08:52 PM
LinearX's Avatar
LinearX
Some photos of the nearly final product.
Stock throttle body versus the 95mm piece from Tracy at RevXtreme.
Old Mar 27, 2008 | 11:43 AM
TLewis4095's Avatar
TLewis4095
Nice setup! Keep the pics coming
Old Mar 27, 2008 | 11:02 PM
LinearX's Avatar
LinearX
Got to drive around a bit this evening. I'm not too sure how many of you would ride around in your Corvettes with the hood off, but I did it!
After getting a few bugs worked out to keep the car from going into reduced power mode, I think I drove it around for an hour or so.
Initial impressions...this things moves a TON of air. I'm going to have to re-learn how to drive. The usual throttle position I'd use to pull away from a light has changed drastically with the heads/cam/throttle body all moving so much more air. I looked like someone that had never driven a stick shift car before.
At ~40% throttle position, 75-80mph comes up quick when getting on the interstate. I can't wait to get it completely dialed in. After driving it around for a bit, I'm a tad more optimistic about the power it's going to make than before.
Old Apr 10, 2008 | 11:36 AM
miami993c297's Avatar
miami993c297
Updates on the progress?
Christian
Old Apr 11, 2008 | 08:48 AM
LinearX's Avatar
LinearX
Christian
I've been working on driveability before putting it on the dyno.
It's a slow process, and I'm not sure how much longer I can handle not knowing how much power it's going to take.
I might have to turn it over to a professional before long!
Old Apr 20, 2008 | 10:15 PM
LinearX's Avatar
LinearX
Finally put the car on the local Mustang Dyno (lovingly referred to as the Heartbreaker) today.
415/368 were the final numbers.
I can't thank Scott at Intune enough for burning his Sunday to do the WOT tuning and touching up the driveability.
He's top notch in every respect, and I feel very lucky to have such a knowledgeable resource so close by.
Old Apr 21, 2008 | 12:38 AM
NemesisC5's Avatar
NemesisC5
I think some forced induction will really help wake'er up, after all you are in the FI section Good Luck with your build
Old Apr 21, 2008 | 07:55 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
Originally Posted by LuvmyC5
Sounds Absolutely SICK! Congratulations!
Old Apr 21, 2008 | 07:57 AM
99 C-5 F1C VETTE
that Rev X looks like an awesume throtle body, its huge
Old Apr 21, 2008 | 11:17 AM
LinearX's Avatar
LinearX
FI would definitely do something to it! I've been FI before in another car I had, so I decided to go NA this go around.
They're super nice pieces. I'm quite pleased with the results!
Old Apr 21, 2008 | 03:06 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Sounds Nasty
