Old Apr 19, 2008 | 02:15 AM
TioSterling's Avatar
TioSterling
Originally Posted by torchvette10
Hi Mike,
I am running a HKE 408 with my little A&A P1SC blower (D1SC or F1A in the future)
I followed Erik's advice and went with a 238/242 on 115+3 LSA. I love the way the car sounds. I am running a 2800 TC and the car idles great at 900 RPM. I just love the way my car runs and sounds (well, when it used to run as I blew my tranny and the car is on the lift )
I also asked Dr Phil what he thinks about the cam and he told me it's a good choice.
Here are the motor specs:
HKE 408 at 9.1 compression
ETP LS1 230cc runners heads
238/242 on 115+3 LSA camshaft
Eagle crank, Callies Rods, Wiseco pistons
A&A P1SC with a 3.55 pulley (over 10# of boost)
With the D1SC, the numbers will be sick!!! Keep us posted
do you have any videos of your car with that cam? I would love to hear it. not to steal the thread or anything but im in the same situation here 408 and will have d1 soon hopefully. looking for a nasty sounding cam but streetable
Old Apr 19, 2008 | 06:43 AM
torchvette10's Avatar
torchvette10
Hi there,
I blew my tranny a few weeks ago and the car is still on the lift. I have a small video of it idling. I am running the stock 99 exhaust with cutouts as I wanted flexibility. I used to have the B&B Bullets but they're loud all the time and with the 408 it would have been too much. Even through the stock exhaust it sounds nasty. I love it.
The cam sounds awesome at WOT, extremely agressive even with the cutouts closed. And the cam idles perfectly at 900 RPM and is very streetable
Here is a small sound clip. It's the setup that you see in my sig but with the stock 99 exhaust (cutouts closed). I need some elctrical motors for the cuouts in the mean time I am running them closed. Quality sux as its from my cellphone
I will make more vids once I get my tranny rebuilt. It should be in the next couple of weeks.
Good luck and I hope I was able to help
Old Apr 19, 2008 | 08:24 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by M_T_0
never was a problem the heads will go on/off over the ARP head studs!!!
it is a close fit but doable.
More Than Zero
Old Apr 19, 2008 | 10:25 AM
TioSterling
Thanks for posting that vid. that is almost the same lope sound I am looking for maybe a little more but i think that headers and no cats with the b and b bullets will be crazy enough. That helped a lot. I know i have to run a 114 lsa but the shop that built the shortblock suggested running a large duration to get the sound i want since i cant run like a 110lsa for the lope. They also said it kinda tames the cam with the bigger cubes compared to the ls1 346 with the same cam. Thanks for posting again
Old Apr 19, 2008 | 09:26 PM
torchvette10
No problem! Glad I was able to help. I am sure your car will sound nasty. Keep in mind that this was the stock exhasut with closed cutouts and AR Headers with high flow cats. You, with no cats and the B&B Bullets will have a sick sick ride that will definitely turn heads and shake the town. I took mine for a ride one with cutouts open and it was very lopey and loud as hell
Good luck with your build
Old Apr 20, 2008 | 04:23 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Im suprised Bryan did talk you to go with compstar for just a little more. Thats what I did. Im almost in the 9's. 10.06@140 !!!!!
Old Apr 20, 2008 | 11:45 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
The motor is at the machine shop and it will be put together next week and then shipped to me! ! As soon as I get it installed, I will post videos! !
I was recommended a 238/242 on 115+3 LSA Cam ! ! !
Old Apr 20, 2008 | 11:51 AM
MIKE-C5's Avatar
MIKE-C5
I didnt buy this motor from Bryan, I bought it from Doug! ! He had all the New Parts and all it need it was to put together! !
Old Apr 20, 2008 | 12:01 PM
MIKE-C5's Avatar
MIKE-C5
Originally Posted by C16-Bandit
Hmmmm, I dont think late Model engines would use Scat parts. Sounds like more of a Texas Speed, or SDPC motor to me.
LME only uses quality parts..I think you'd have to beg them to run those internals.
DUDE! ! !
Please re-read the post, no where do I state its an LME Motor! ! !
Thats how Rumors get started! !
Old Apr 20, 2008 | 05:54 PM
Higgs Boson's Avatar
Higgs Boson
Originally Posted by MIKE-C5
DUDE! ! !
Is something messed up with the dates on your view style? he said that before you clarified.... why are you replying now? strange, man.
Old Apr 20, 2008 | 06:45 PM
Vietnam Vette Medevacs's Avatar
Holdner made 1200hp on an Iron block and Scat crank and rods with probe pistons and I believe Mamos heads and a 91mm . I just bought the same parts for my short block.
Old Apr 20, 2008 | 07:04 PM
TioSterling
man i bet you are excited. the speed shop called thursday and said my 408 shortblock was ready for pickup but i need to get the other block tore down and ready to switch the parts over so im going to pick it up friday and need to get a cam and timing chain so i can set it in the car. good luck on your build im sure its gonna sound awesome im looking forward to the videos
Old Apr 20, 2008 | 07:11 PM
  #33
blwnc5's Avatar
blwnc5
I heard Scat can hold a lot of power and boost, Let me know if this is true.
Old Apr 20, 2008 | 08:44 PM
  #34
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Well guys, Im building a 408 to replace my 383.
I will be at 9.5:1 in compression to run my D1SC with it.
-GM 6.0L Iron block bored (.30 over)
-SCAT 4340 4.0" stroke
-SCAT 6.125" H beam rods w/ ARP 2000 7/16" bolts
-Wiseco forged 4.030" -15cc dish pistons
-Childs & Albert Fire Power rings (for high heat applications)
-ARP Main Studs
-Clevite MS 2199 H main bearings
-Clevite CB 745 H rod bearings
-Dura Bond CH-23 cam beraings
-Ported Patriot LQ9 Heads Stage 3 (72cc)
-ARP Head Studs
I'm shopping around for the cam, so if you have any opinions/recomendations, I would like to hear them! !
Also, anyone here running a 408 with a blower? ?
Sounds like a nice package, who's doing the install for ya?
Old Apr 20, 2008 | 09:26 PM
  #35
MIKE-C5's Avatar
MIKE-C5
Cant wait
Old Apr 20, 2008 | 09:27 PM
  #36
MIKE-C5's Avatar
MIKE-C5
Arnold (gotjuice?)
Old Apr 20, 2008 | 09:43 PM
  #37
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Arnold (gotjuice?)
That's what I figured. You and Steve going to supervise.
Sounds like a pretty stout package, that can take the boost and heat, looking forward to your install thread.
Old Apr 21, 2008 | 10:04 PM
  #38
MIKE-C5's Avatar
MIKE-C5
I will be starting a thread as soon as I get the Motor! !
Old Apr 21, 2008 | 11:01 PM
  #39
vetterlatethannever's Avatar
vetterlatethannever
Sounds like a beast!!!
Kep us posted!
