Anyone regret going with meth?
and methane will stink up the place good....if you mean good old fashioned alky....it rocks....just ask funcool....I am still waiting for himto show us how good his kit really is.
Remember that Meth cools the intake charge for the motor and can cool the cylinders up to 250* which will enable you to utalize and make more HP and TQ at the RW's.
It is cheap insurance against DETONATION! and HEAT which is a huge enemy in FI!
Hope this helps!
Thanks,Matt
That being said, I've found meth can be a great tool to compensate for a mostly stock fuel system as well to maintain power in the summer heat.
But there is no free lunch, meth is something that requires maintenance.
The tanks can leak, the meth slowly evaporate, washers can erode over time, the pumps are only good for a couple of seasons, etc, plus you have the added hassle of making sure the tank stays full.
Plus, if you run the standard setup you lose your windshield washer tank, which is pretty ghetto in my opinion. We're talking Vettes here, not old Mustangs or Camaros.
Your other option would be a custom tank / mounting solution, but that can take some experimenting as you need to find a good EXTERNAL mounting location that is at least moderately accessible, a tank that won't leak (some of the tanks can develop cracks around the filling neck over time), etc.
I'm not really trying to discourage necessarily from a meth setup, but I'd definitely recommend considering the pros and cons and why exactly you want it. Consider what problem you are trying to solve and evaluate your options carefully.
