P1SC vs D1SC
Old Apr 22, 2008 | 08:38 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by 03blackZ06
Im new to getting into FI i need to know what is the better supercharger to go with and why. My car is an 03 z06 longtubes xpipe no cats prt exhaust and intake. I am going to do cam and supercharger install. The price is going to be the same if i buy this used kit with a P1SC vs a D1sc. what should i go with and why? Thanks mike
Definetely go with the "D"...Is an 8-rib vs a 6-rib an option? "Ribbed for Her Pleasure"
Old Apr 23, 2008 | 10:12 AM
03blackZ06's Avatar
03blackZ06
what size pullies should i use for 4-6 lbs of boost? thanks mike
Old Apr 23, 2008 | 12:23 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
A large one probably close to 5"
Old Apr 23, 2008 | 03:31 PM
vetterlatethannever's Avatar
vetterlatethannever
I asked about upgrading my P to a D and they recommended no smaller than a 4.5"
Old Apr 23, 2008 | 03:44 PM
Indiana Z06's Avatar
Indiana Z06
That's the size pulley that I got with my ECS system with the D1SC. I would assume it should make around 8 lbs.
Old Apr 23, 2008 | 05:05 PM
Mr.Big's Avatar
Mr.Big
If you must go ATI go F1A to start... But I would go ECS with the novi 2000...
But just as an FYI here is my dyno from yesterday with my little 'ol P1SC at 9psi... First is a comparison between the first rough tune to a "safe" fine tune... Check the gains trough out the rev range... second sheet was max powaaaaa....
I have 25,000+ miles above 620rwhp, the fuel pump finally took a dump so we built a custom fuel system and upped the boost... F1C and forged 402 in the works...
Old Apr 23, 2008 | 08:49 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I do not agree on starting with a F1A, I qualify this with he is staying with a stock bottom to start and the DS1C is the perfect blower for him to start with. I make 750 rwhp and do this with a little ole 347 at 14lbs of boost so it will make some nice numbers and if he wants to turn up to 16lbs 800 is no issue and I make mine with a baby cam and LS6 heads so 800 is nothing, now if he wants big numbers then F1A or bigger. If he gets an A&A bracket or ECS one there are no issues with running the ATI setup I know my A&A bracket rocks, so he does not need to get a Novi unless he wants one and those are kick *** setups that will put down the numbers to, but he did ask for info on ATI head units. Your setup is awesome and when you go 402 bigger is on the way and looking forward to seeing the end result
Old Apr 23, 2008 | 09:52 PM
vetterlatethannever
What size motor and is this with the NOS?
Old Apr 23, 2008 | 10:13 PM
Mr.Big's Avatar
Mr.Big
STOCK LS2 & 243's except for ECS blower cam... No N2O on these runs...
Peterpan,
I say F1A to start because it can easily be pullied down for low boost apps., and there is far more potential than the P1 or D1. I rode in a stock except for F1A LS2 C6 at 7psi and it drove great... No Lag what so ever... so in the name of potential I say F1A...
Old Apr 23, 2008 | 10:14 PM
Mr.Big's Avatar
Mr.Big
P.S. the N2O adds 125rwhp across the board...
Old Apr 23, 2008 | 11:27 PM
vetterlatethannever
Old Apr 24, 2008 | 08:10 AM
03blackZ06's Avatar
03blackZ06
what other mods should i do at the same time as the super chager install? I have full intake and exhaust. thanks mike
Old Apr 24, 2008 | 03:28 PM
  #33
Mr.Big's Avatar
Mr.Big
ALKY Control kit, for sure!!! and depending on the system you buy 60lb injectors and B.A.P. (the ECS kit comes with injectors and bap)... That's it...
Old Apr 24, 2008 | 05:14 PM
  #34
peter pan's Avatar
peter pan
Life Time NCM #2196
Meth and big injectors are a must, I use all of the above on mine and they all work like a champ
Old Apr 25, 2008 | 12:51 AM
  #35
03blackZ06's Avatar
03blackZ06
even for just wanting 500 to 550 at the rear wheels with 8lbs of boost? No cam ,clutch, tork tubes, hardened output shafts, 160 stat? thanks mike
Old Apr 25, 2008 | 01:03 AM
  #36
CraZee ZO6's Avatar
CraZee ZO6
d1sc only way to fly from low boost setup to big boost nasty setup
Old Apr 26, 2008 | 12:59 AM
  #37
03blackZ06's Avatar
03blackZ06
thanks
To P1SC vs D1SC
Old Apr 26, 2008 | 09:37 AM
  #38
robert miller's Avatar
robert miller
sounds like also D1. dont sound like he is there yet for the f1r just have fun man, good luck...
Old Apr 26, 2008 | 11:04 AM
  #39
CraZee ZO6's Avatar
CraZee ZO6
f1-r is a baaad baaad boy but for stock bottom end d1sc can be run better, safer. Then on a built motor you can still make respectable big #s with the d1.
f1-r is straight loud nasty and big boost.
Old Apr 27, 2008 | 09:38 PM
  #40
EPP's Avatar
0EPP
Former Vendor
The Procharger P and D series of blowers have a 4:10/1 step up ratio, the F series have a 5:40/1 step up ratio. Slowing an F series blower down to produce the lower boost necessary to keep a stock bottom end alive is tricky. One of my customer's had a one off 5.50 blower pulley made to slow down his F-1A on his GTO. The GTO though uses a smaller 7.00" crank blower pulley, which helped him out even further. When having a larger custom made pulley created, you need to make sure you will have hood clearance for it. Bob
