Good blower cam spec's
Old Apr 29, 2008 | 11:52 PM
03blackZ06's Avatar
03blackZ06
Default Good blower cam spec's
Looking for some good blower cam specs something in the middle of mild and wild. I would like to do a cam at the same time as i put the procharger kit on. also is an aftermarket 25% underdrive pully necessary? thanks mike
Old Apr 29, 2008 | 11:58 PM
bullitt4110's Avatar
bullitt4110
You dont want a underdrive pulley with the supercharger, it will lower your boost and may cause belt slip. If anything you would go with and overdrive pulley, but if you are on stock motor the stock pulley will work just fine.
Old Apr 30, 2008 | 08:00 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Apr 30, 2008 | 09:11 AM
03blackZ06's Avatar
03blackZ06
ok so no on the u/d pully any help on cam specs what should i look for? thanks mike
Old Apr 30, 2008 | 10:13 AM
chriswtx's Avatar
chriswtx
small 224/228 114LSA .580ish lift
med 228/236 114LSA .590ish lift
large 234/240 114LSA .600ish lift
Comp Cam XER lobes prefered... I'm running a med. cam 226/232 .588/.596 lift on a 116LSA..Runs and idles nice. The first 2 will make great power and idle nice with the last one having a large lopey idle..
Old Apr 30, 2008 | 10:45 AM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Very nice specs Chris!
Old Apr 30, 2008 | 12:01 PM
03blackZ06's Avatar
03blackZ06
what about this
228/236 .571"/578" 114lsa
or 228/236 .588"/.602" 114lsa
or 228/234 .588"/.598" 114lsa
Old Apr 30, 2008 | 12:25 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I run the baby cam specs and seems to work fine on my 347
Old Apr 30, 2008 | 12:39 PM
chriswtx's Avatar
chriswtx
228/236 .588"/.602" 114lsa would be my vote... 228/236 .571"/578" 114lsa is roughly the same, just a less aggressive cam lobe, easier on the valve springs...both can make 750-800rwhp with the right setup..
Old Apr 30, 2008 | 01:12 PM
MotleyDrew's Avatar
MotleyDrew
ha...thats not small
214/226 569/579 115 lsa here almost stock like
Old Apr 30, 2008 | 08:12 PM
petercln's Avatar
petercln
214/226 569/579 here almost stock like
207/220 571/578 118.5
Mines about as small as yours. that didnt sound right
Old Apr 30, 2008 | 08:35 PM
Carl Spackler's Avatar
Carl Spackler
St. Jude Donor '08
My P1SC-equipped vert had great results w/EnglandGreen's Whiplash cam. Car went from 430rwhp to 507rwhp. Specs are proprietary, but it's low 240's duration and low .600's lift.
Old Apr 30, 2008 | 09:11 PM
MotleyDrew's Avatar
MotleyDrew
ya....I'm white
Old Apr 30, 2008 | 09:25 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
It really matter's on what mods you have.I prefer the small duration Cams for a stock drivability.Just finished a stock motor 02 Z06 with 10lbs,meth ect that made north of 700rwhp/580tq with a very small duration,high lift Cam,stock heads.
Old Apr 30, 2008 | 09:34 PM
Dave concrete's Avatar
Dave concrete
Will the large cam be loud and lumpy because that is what I want.How do you think it will sound with long tubes,x-pipe hi-flows and titaniums. Is this cam to aggresive for a novi blower.
Old Apr 30, 2008 | 10:30 PM
94-vette's Avatar
94-vette
I like the G5X3 and the MS4!!!
Old Apr 30, 2008 | 10:36 PM
03blackZ06's Avatar
03blackZ06
i woudl also get to pick my intake center lobe ranging f4rom 106 to 118 should this be the same as the lsa? or different and if so why? thanks mike
To Good blower cam spec's
Old May 1, 2008 | 12:32 AM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
ECS and A&A have good Blower cams, but if you want nasty call England Green
Old May 1, 2008 | 01:48 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Mike...How about a 228/232 .595/.598 on a 114lsa?
It just came out of the vette
AS for as a pulley, you really want an ECS overdrive pulley, if you're going to go that route.
My new cam is a 228/236 .588/.601 on a 116lsa
Old May 1, 2008 | 09:54 AM
03blackZ06's Avatar
03blackZ06
interesting i emailed you
