Cam Option
Old May 10, 2008 | 03:41 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Cam Option
What do you guys think about this cam for a 408 with a D1SC.
Comp Cams # 54-000-11 / G5X-2 Hyd. Roller Cam for LS1/2/6 1997-up. 232/240dur. @.050" . .595/.608 " lift. on a 114 LSA
Old May 10, 2008 | 05:23 PM
mdhmi's Avatar
mdhmi
I think that would be a lovely cam, for a NA 346.
Old May 10, 2008 | 06:21 PM
chriswtx's Avatar
chriswtx
Old May 10, 2008 | 08:00 PM
NemesisC5's Avatar
NemesisC5
That cam will work great in your setup THE same cam I would choose right now if I were doing a build. Arun at Canadian Performance has been experimenting with some cams that WERE typically considered NA only cams & has found that some of them work exceptionally well. The cam specs you list even mirror the typical "blower cam" but are just more aggressive
Old May 10, 2008 | 08:22 PM
bullitt4110's Avatar
bullitt4110
That would work very well, I know a few people running cams around that size with 402+ci and blowers and making some really good power.
Old May 10, 2008 | 10:40 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
That is a nice daily driver type of Cam with alittle lope.
Old May 11, 2008 | 06:33 AM
EPP's Avatar
0EPP
Former Vendor
http://www.exoticperformanceplus.com....html?item=679
It is almost identical to the spec's on our blower camshaft. Bob
Old May 11, 2008 | 08:19 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Smaller cam for that Cube motor will be great and make some great numbers!
Go with it
Thanks,Matt
Old May 11, 2008 | 09:07 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
I would go a tad bigger Mike but that cam will work great. It's a bit small for a 408 but will still work well-just make sure the CR is not in the dumps.
To Cam Option
